주요 콘텐츠로 건너뛰기
2011 Ford Fiesta Headlight Replacement
필요한 것
  1. 2011 Ford Fiesta Headlight Replacement, Indicator Bulb: 1 단계, 이미지 1/1
    • Park the car where you have room to work.
    • Check that the hand brake is on and the engine is off.
    • Wait for the car to cool down before opening the hood. The hot air from the engine may damage the eyes and cause burns.
    • Ensure that the car has rested for at least 30 minutes.
  2. 2011 Ford Fiesta Headlight Replacement: 2 단계, 이미지 1/3 2011 Ford Fiesta Headlight Replacement: 2 단계, 이미지 2/3 2011 Ford Fiesta Headlight Replacement: 2 단계, 이미지 3/3
    • Pull the hood release under the driver's dashboard towards you.
  3. 2011 Ford Fiesta Headlight Replacement: 3 단계, 이미지 1/3 2011 Ford Fiesta Headlight Replacement: 3 단계, 이미지 2/3 2011 Ford Fiesta Headlight Replacement: 3 단계, 이미지 3/3
    • Make sure there is space to insert fingers. If not, repeat step 2.
    • Push the yellow hood release to the left to open the hood.
  4. 2011 Ford Fiesta Headlight Replacement: 4 단계, 이미지 1/2 2011 Ford Fiesta Headlight Replacement: 4 단계, 이미지 2/2
    • Lift the hood with one hand and place the strut upright in the correct position.
    • Place strut in the hole to the left of the hood.
  5. 2011 Ford Fiesta Headlight Replacement: 5 단계, 이미지 1/3 2011 Ford Fiesta Headlight Replacement: 5 단계, 이미지 2/3 2011 Ford Fiesta Headlight Replacement: 5 단계, 이미지 3/3
    • Use a flathead screwdriver to loosen the lower retained screw.
    • Collect the screws and store them somewhere safe.
  6. 2011 Ford Fiesta Headlight Replacement: 6 단계, 이미지 1/2 2011 Ford Fiesta Headlight Replacement: 6 단계, 이미지 2/2
    • Remove the upper retained screw.
    • Store the screw in a safe place.
  7. 2011 Ford Fiesta Headlight Replacement: 7 단계, 이미지 1/3 2011 Ford Fiesta Headlight Replacement: 7 단계, 이미지 2/3 2011 Ford Fiesta Headlight Replacement: 7 단계, 이미지 3/3
    • Carefully remove the headlight.
    • The headlight is attached to three electrical connectors.
    • Gently pull up and towards your body.
    • Set the headlight to the side.
  8. 2011 Ford Fiesta Headlight Replacement: 8 단계, 이미지 1/3 2011 Ford Fiesta Headlight Replacement: 8 단계, 이미지 2/3 2011 Ford Fiesta Headlight Replacement: 8 단계, 이미지 3/3
    • Press both ends of the bulb container to remove the electrical connector from the bulb container.
  9. 2011 Ford Fiesta Headlight Replacement: 9 단계, 이미지 1/3 2011 Ford Fiesta Headlight Replacement: 9 단계, 이미지 2/3 2011 Ford Fiesta Headlight Replacement: 9 단계, 이미지 3/3
    • Pull out the bulb from the headlight.
    • Press both ends of the electrical connector to separate from the bulb container.
  10. 2011 Ford Fiesta Headlight Replacement: 10 단계, 이미지 1/1
    • Make sure you do not hold the glass surface with your bare hands. The bulb may malfunction from the sweat in your hands.
    • Hold the black part of the bulb.
    • The bulb might break, so be sure to wear gloves and protective glasses.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Phillip Kataswa
회원 가입일: 07/01/21
208 평판
안내서 1개 작성함
York University, Team S2-G13, Melo-Thaiss Summer 2021 York University, Team S2-G13, Melo-Thaiss Summer 2021 회원
YORK-MELO-THAISS-SU21S2G13
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 32
30일 전: 217
전체 시간: 5,388
