주요 콘텐츠로 건너뛰기
2011 Ford Focus Air Conditioning Refrigerant Replacement
필요한 것
  1. 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: 1 단계, 이미지 1/3 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: 1 단계, 이미지 2/3 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: 1 단계, 이미지 3/3
    • Turn the car on and the A/C to the maximum.
  2. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: 2 단계, 이미지 1/1
    • Open your car's hood.
  3. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: 3 단계, 이미지 1/2 2011 Ford Focus Air Conditioning  Refrigerant Replacement: 3 단계, 이미지 2/2
    • Locate the low-pressure charging port.
  4. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: 4 단계, 이미지 1/1
    • Remove the cap by turning it counter-clockwise.
  5. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: 5 단계, 이미지 1/2 2011 Ford Focus Air Conditioning  Refrigerant Replacement: 5 단계, 이미지 2/2
    • Connect the nozzle and hold the canister at a 3 o'clock angle.
    • Warning: Keep an eye on the PSI level. It should stay between 30 and 50, as going beyond 50 psi could cause the car's compressor to become damaged.
    • Lock and remove the canister if it is around 40 to prevent it from going to 50 psi.
    • Finally, start up the car. If the air conditioning is cooler, you'll know that it works!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Sujan
회원 가입일: 03/07/22
130 평판
안내서 1개 작성함
University of North Texas, Team 1-2, Raign Spring 2022 University of North Texas, Team 1-2, Raign Spring 2022 회원
UNT-RAIGN-S22S1G2
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 59
30일 전: 268
전체 시간: 4,501
