소개
This guide is for base model Mazda 3 owners who need to replace their factory OEM door speakers.
Perform this repair while the car is off.
The speaker in this guide is a component speaker, so they do not require any wire cutting or soldering.
필요한 것
Pry the door handle cover upwards using a flathead screwdriver.
Remove the cover to expose the screw.
이 단계에 사용된 도구:Heavy-Duty Spudger$4.99
Pry the door cover away from the frame using a heavy-duty spudger.
다른 2명이 해당 안내서를 완성하였습니다.
