주요 콘텐츠로 건너뛰기
2011 Scion Tc Blower Motor Replacement
필요한 것
  1. 2011 Scion Tc Blower Motor Replacement, Blower Motor: 1 단계, 이미지 1/1
    • Locate your blower motor. Your blower motor should be below the glovebox.
  2. 2011 Scion Tc Blower Motor Replacement: 2 단계, 이미지 1/1
    • Remove the three 2 mm screws that secure the blower motor.
  3. 2011 Scion Tc Blower Motor Replacement: 3 단계, 이미지 1/1
    • Remove the two 1 mm Phillips #0 screws that secure the blower motor wiring harness.
  4. 2011 Scion Tc Blower Motor Replacement: 4 단계, 이미지 1/2 2011 Scion Tc Blower Motor Replacement: 4 단계, 이미지 2/2
    • Disconnect the sensor that is connect to the blower motor.
    • The sensor should have a click and carefully remove it upwards.
  5. 2011 Scion Tc Blower Motor Replacement: 5 단계, 이미지 1/2 2011 Scion Tc Blower Motor Replacement: 5 단계, 이미지 2/2
    • Put the new blower motor in place, and secure it with the three 2 mm Phillips #0 screws.
  6. 2011 Scion Tc Blower Motor Replacement: 6 단계, 이미지 1/1
    • Tighten the two 1 mm screws to the wiring harness.
  7. 2011 Scion Tc Blower Motor Replacement: 7 단계, 이미지 1/1
    • Congratulations, you have successfully replaced your blower motor!
    • Once all the screws are tightened, just make sure to turn on your air to see if your blower motor works!
결론
Jose Ruvalcaba
회원 가입일: 05/04/22
145 평판
안내서 1개 작성함
CSU Los Angeles, Team 13-13, Harris Spring 2022 CSU Los Angeles, Team 13-13, Harris Spring 2022 회원
CSULA-HARRIS-S22S13G13
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Is the blower motor inside of the car under the glovebox? Do I need to replace the glovebox to get to the blower motor?
Christopher Sean Harris - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 37
전체 시간: 1,128
