주요 콘텐츠로 건너뛰기
2011 Toyota Sienna Headlight Bulb Replacement
필요한 것
  1. 2011 Toyota Sienna Headlight Bulb Replacement, Headlight Bulb: 1 단계, 이미지 1/3 2011 Toyota Sienna Headlight Bulb Replacement, Headlight Bulb: 1 단계, 이미지 2/3 2011 Toyota Sienna Headlight Bulb Replacement, Headlight Bulb: 1 단계, 이미지 3/3
    • Pull out the hood release latch located towards the lower left of the steering wheel.
  2. 2011 Toyota Sienna Headlight Bulb Replacement: 2 단계, 이미지 1/3 2011 Toyota Sienna Headlight Bulb Replacement: 2 단계, 이미지 2/3 2011 Toyota Sienna Headlight Bulb Replacement: 2 단계, 이미지 3/3
    • Hold up the hood safety latch with one hand and lift the hood of the car with the other hand.
    • Pull the hood all the way up to ensure it engages and stays up.
  3. 2011 Toyota Sienna Headlight Bulb Replacement: 3 단계, 이미지 1/2 2011 Toyota Sienna Headlight Bulb Replacement: 3 단계, 이미지 2/2
    • Locate the headlight bulb housings on each side if the hood.
    • It's advisable to replace both headlights even if only one is burned out. The other light is likely to go out soon, and replacing both now can help avoid additional repairs.
  4. 2011 Toyota Sienna Headlight Bulb Replacement: 4 단계, 이미지 1/3 2011 Toyota Sienna Headlight Bulb Replacement: 4 단계, 이미지 2/3 2011 Toyota Sienna Headlight Bulb Replacement: 4 단계, 이미지 3/3
    • Push the button on the electrical connector until you hear a click.
    • Pull down to remove the electrical connector.
  5. 2011 Toyota Sienna Headlight Bulb Replacement: 5 단계, 이미지 1/2 2011 Toyota Sienna Headlight Bulb Replacement: 5 단계, 이미지 2/2
    • Twist the bulb counter clockwise.
  6. 2011 Toyota Sienna Headlight Bulb Replacement: 6 단계, 이미지 1/1
    • Pull out the bulb.
    • Insert your new light bulb.
    • If you are not wearing gloves, avoid touching the glass part of the bulb since the oils from your skin will damage the bulb.
결론
Madeleine Falcon
회원 가입일: 09/07/23
183 평판
안내서 1개 작성함
York University, Team 1-11, O'Regan Fall 2023 York University, Team 1-11, O'Regan Fall 2023 회원
YORK-O'REGAN-F23S1G11
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 31
전체 시간: 269
