소개
Use this guide to correctly replace the headlight bulbs on a 2011 Volkswagen Eos.
Before using this guide be sure to have nylon gloves on to prevent the oils on your hand from transferring to the new bulbs. The oils will heat faster than the glass, causing the glass to shatter once the bulb is turned on.
필요한 것
거의 끝나갑니다!
With the completion of the guide, your headlight LED should be working.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
