주요 콘텐츠로 건너뛰기
2012-Present Toyota Corolla Windshield Wiper Replacement
필요한 것
  1. 2012-Present Toyota Corolla Windshield Wiper Replacement, Windshield Wiper: 1 단계, 이미지 1/2 2012-Present Toyota Corolla Windshield Wiper Replacement, Windshield Wiper: 1 단계, 이미지 2/2
    • Lift up the windshield wiper you're replacing.
  2. 2012-Present Toyota Corolla Windshield Wiper Replacement: 2 단계, 이미지 1/2 2012-Present Toyota Corolla Windshield Wiper Replacement: 2 단계, 이미지 2/2
    • Insert a flathead screwdriver into the locking mechanism of the wiper and gently pry it open.
    • You can use your car keys in case you do not have a screwdriver.
  3. 2012-Present Toyota Corolla Windshield Wiper Replacement: 3 단계, 이미지 1/2 2012-Present Toyota Corolla Windshield Wiper Replacement: 3 단계, 이미지 2/2
    • Push the wiper blade downwards until it locks into place.
  4. 2012-Present Toyota Corolla Windshield Wiper Replacement: 4 단계, 이미지 1/2 2012-Present Toyota Corolla Windshield Wiper Replacement: 4 단계, 이미지 2/2
    • Angle the wiper away from you, so that the top is near you while the bottom is farther away.
    • Gently push the blade out of the wiper base.
  5. 2012-Present Toyota Corolla Windshield Wiper Replacement: 5 단계, 이미지 1/2 2012-Present Toyota Corolla Windshield Wiper Replacement: 5 단계, 이미지 2/2
    • Bring the new wiper blade into the wiper base from the car, aiming it so that the wiper base enters the lock hole.
    • Once the wiper blade is in, hold it from the bottom and push it upwards to secure the hold.
    • Make sure to start with the lock open, and that the blade is facing the same direction as the picture.
  6. 2012-Present Toyota Corolla Windshield Wiper Replacement: 6 단계, 이미지 1/3 2012-Present Toyota Corolla Windshield Wiper Replacement: 6 단계, 이미지 2/3 2012-Present Toyota Corolla Windshield Wiper Replacement: 6 단계, 이미지 3/3
    • Push down the lock with force until it clicks.
  7. 2012-Present Toyota Corolla Windshield Wiper Replacement: 7 단계, 이미지 1/1
    • Repeat for the second blade.
    • Your windshield wiper blade replacement is now complete!
결승점
Yusuf Gabaire
회원 가입일: 07/03/21
157 평판
안내서 1개 작성함
York University, Team 2-6, O'Regan Fall 2021 York University, Team 2-6, O'Regan Fall 2021 회원
YORK-O'REGAN-F21S2G6
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 29
30일 전: 137
전체 시간: 2,899
