주요 콘텐츠로 건너뛰기
2012-2018 Ford Focus Side Marker Light Replacement
필요한 것
  1. 2012-2018 Ford Focus Side Marker Light Replacement, Side Marker Light: 1 단계, 이미지 1/3 2012-2018 Ford Focus Side Marker Light Replacement, Side Marker Light: 1 단계, 이미지 2/3 2012-2018 Ford Focus Side Marker Light Replacement, Side Marker Light: 1 단계, 이미지 3/3
    • Release the hood lock found in the driver-side foot-well.
    • Find the latch under the center of the hood.
    • Depress the latch to release the hood.
    • Aline the hood strut into the designated hole to keep the hood open while working.
  2. 2012-2018 Ford Focus Side Marker Light Replacement: 2 단계, 이미지 1/3 2012-2018 Ford Focus Side Marker Light Replacement: 2 단계, 이미지 2/3 2012-2018 Ford Focus Side Marker Light Replacement: 2 단계, 이미지 3/3
    • Remove the screws connected to the headlamp using the Torx T30 socket wrench OR 10 mm flat head screwdriver.
  3. 2012-2018 Ford Focus Side Marker Light Replacement: 3 단계, 이미지 1/2 2012-2018 Ford Focus Side Marker Light Replacement: 3 단계, 이미지 2/2
    • Pull the headlamp carefully upwards towards the hood until you hear a click.
  4. 2012-2018 Ford Focus Side Marker Light Replacement: 4 단계, 이미지 1/3 2012-2018 Ford Focus Side Marker Light Replacement: 4 단계, 이미지 2/3 2012-2018 Ford Focus Side Marker Light Replacement: 4 단계, 이미지 3/3
    • Disconnect the headlamp
    • Please be careful when disconnecting the headlamp because it is fragile
  5. 2012-2018 Ford Focus Side Marker Light Replacement: 5 단계, 이미지 1/3 2012-2018 Ford Focus Side Marker Light Replacement: 5 단계, 이미지 2/3 2012-2018 Ford Focus Side Marker Light Replacement: 5 단계, 이미지 3/3
    • Twist the bulb cover counterclockwise.
    • Be careful when removing the bulb cover because it is fragile.
  6. 2012-2018 Ford Focus Side Marker Light Replacement: 6 단계, 이미지 1/3 2012-2018 Ford Focus Side Marker Light Replacement: 6 단계, 이미지 2/3 2012-2018 Ford Focus Side Marker Light Replacement: 6 단계, 이미지 3/3
    • Pull on the bulb cover to take out the bulb holder.
  7. 2012-2018 Ford Focus Side Marker Light Replacement: 7 단계, 이미지 1/1
    • Pull the bulb out of the bulb holder.
    • These bulb are fine to throw away with your regular trash.
  8. 2012-2018 Ford Focus Side Marker Light Replacement: 8 단계, 이미지 1/2 2012-2018 Ford Focus Side Marker Light Replacement: 8 단계, 이미지 2/2
    • Press the new bulb into the bulb holder.
    • Do not touch the bulb with your bare hands. The oil from your hands can cause the bulb to shatter as it heats up. If you do touch the bulb, be sure to wipe the bulb clean with an alcohol wipe.
결론
Austyne Chetwood
회원 가입일: 10/06/22
157 평판
안내서 1개 작성함
University of North Texas, Team 2-5, Raign Fall 2022 University of North Texas, Team 2-5, Raign Fall 2022 회원
UNT-RAIGN-F22S2G5
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 68
30일 전: 218
전체 시간: 3,221
