주요 콘텐츠로 건너뛰기
2012-2018 Nissan Versa Note Headlight Bulb Replacement
필요한 것
  1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: 1 단계, 이미지 1/2 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: 1 단계, 이미지 2/2
    • Pull the hood lever.
  2. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 2 단계, 이미지 1/1
    • Push the lever underneath the hood to the left.
    • The lever is located in the center underneath the hood.
  3. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 3 단계, 이미지 1/1
    • Pull up the hood.
  4. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 4 단계, 이미지 1/1
    • Insert the support rod into the slot.
    • The stent is located to the right of the hood.
    • The slot is located in the underside of the hood to the right.
  5. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 5 단계, 이미지 1/2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 5 단계, 이미지 2/2
    • Pull out the connector from the bulb.
    • Depending on the make of your vehicle, you may have push the tab on the connector that reads "push" before pulling out the connector.
  6. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 6 단계, 이미지 1/1
    • Twist the plastic ring out from the bulb.
  7. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 7 단계, 이미지 1/2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 7 단계, 이미지 2/2
    • Pull out the old bulb.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
  8. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 8 단계, 이미지 1/2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 8 단계, 이미지 2/2
    • Insert the replacement bulb.
  9. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 9 단계, 이미지 1/1
    • Twist the plastic ring back onto the bulb.
  10. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 10 단계, 이미지 1/2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 10 단계, 이미지 2/2
    • Insert the connector into the bulb.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Chelsea Chineme
회원 가입일: 09/28/21
229 평판
안내서 1개 작성함
University of North Texas, Team 2-8, Raign Fall 2021 University of North Texas, Team 2-8, Raign Fall 2021 회원
UNT-RAIGN-F21S2G8
2 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 44
30일 전: 213
전체 시간: 12,802
