주요 콘텐츠로 건너뛰기
2012-2017 Toyota Camry Key Battery Replacement
필요한 것
동영상 지침
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
eCuration
회원 가입일: 05/19/17
450,149 평판
안내서 252개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
6가이드 댓글
Thanks! So easy and just what I needed to know.
Melodie Mangers - 답글
I did that & my fob still isn't working. Does it need to be reset?
Thanks in advance
Debbie
Deborah Garza - 답글
You need a 2032 battery not 2016
lordbob75 - 답글
The battery in the vid clearly shows "CR 2016."
Steffi Kaizun (Skaizun) -
You don't need your fingernail to separate the clear and black pieces. At about the 54 second mark, a white tab is visible at the right (short) end of the piece. GENTLY push a jeweler's flathead screwdriver into it until you feel the clear and black pieces separating. You can do the rest with your fingernail. Use the same screwdriver between the copper battery holder and the battery to lift it out, then stick the new one into the copper holder, then push down as you push toward the copper holder to set the new battery. Keep in mind that while you're replacing the battery, you may be pushing the buttons, so, make sure to test the fob from at least 10 feet away: (1) Make sure the trunk is closed; if not, close it, manually; then, open it with the remote, then close it, manually. (2) test the door lock buttons. (3) test the alarm.
Steffi Kaizun (Skaizun) - 답글
댓글 쓰기
조회 통계:
지난 24시간: 32
지난 7일: 172
지난 30일: 799
전체 시간: 117,382
