주요 콘텐츠로 건너뛰기
2012-2016 Honda CR-V Cabin Air Filter Replacement
필요한 것
  1. 2012-2016 Honda CR-V Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 1/3 2012-2016 Honda CR-V Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 2/3 2012-2016 Honda CR-V Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 3/3
    • Open the glove box by pulling the handle towards you.
  2. 2012-2016 Honda CR-V Cabin Air Filter Replacement: 2 단계, 이미지 1/2 2012-2016 Honda CR-V Cabin Air Filter Replacement: 2 단계, 이미지 2/2
    • Empty the glove box for an easier repair experience.
    • Push the latch at the bottom right of the glove box towards the front of the vehicle until the latch becomes unhinged.
  3. 2012-2016 Honda CR-V Cabin Air Filter Replacement: 3 단계, 이미지 1/3 2012-2016 Honda CR-V Cabin Air Filter Replacement: 3 단계, 이미지 2/3 2012-2016 Honda CR-V Cabin Air Filter Replacement: 3 단계, 이미지 3/3
    • Push both sides of the glove box towards each other and pull down to release glove box.
    • The glove box will drop towards the floor so be prepared to hold on or it will fall to the floor.
    • The cabin air filter is located behind the glove box.
  4. 2012-2016 Honda CR-V Cabin Air Filter Replacement: 4 단계, 이미지 1/2 2012-2016 Honda CR-V Cabin Air Filter Replacement: 4 단계, 이미지 2/2
    • Push the tabs on the left and right side of the air filter compartment inward, to remove the cover.
  5. 2012-2016 Honda CR-V Cabin Air Filter Replacement: 5 단계, 이미지 1/1
    • Pull out the old air filter.
  6. 2012-2016 Honda CR-V Cabin Air Filter Replacement: 6 단계, 이미지 1/1
    • Slide the new air filter into the compartment.
    • Remember to match the air flow indicators on the front of the filter and the compartment.
결론
EdreesA
회원 가입일: 09/10/23
133 평판
안내서 1개 작성함
York University, Team 1-4, O'Regan Fall 2023 York University, Team 1-4, O'Regan Fall 2023 회원
YORK-O'REGAN-F23S1G4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 82
30일 전: 406
전체 시간: 1,761
