주요 콘텐츠로 건너뛰기
2012-2016 Honda CR-V Oil and Oil Filter Replacement
필요한 것
  1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: 1 단계, 이미지 1/2 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: 1 단계, 이미지 2/2
    • Open the hood by pulling the hood latch.
    • Oil may be hot if the engine has not cooled.
    • Keep vehicle in park and off unless otherwise noted.
    • Chock both back wheels with blocks of wood to prevent car from rolling.
  2. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 2 단계, 이미지 1/2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 2 단계, 이미지 2/2
    • Let the vehicle cool for 15 minutes if needed. Clean the area around the oil cap. Remove the oil cap.
  3. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 3 단계, 이미지 1/3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 3 단계, 이미지 2/3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 3 단계, 이미지 3/3
    • Locate the dipstick and check oil level.
  4. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 4 단계, 이미지 1/1
    • Place the drain pain under the chassis and align with the drain bolt.
  5. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 5 단계, 이미지 1/1
    • Locate the drain bolt.
  6. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 6 단계, 이미지 1/3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 6 단계, 이미지 2/3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 6 단계, 이미지 3/3
    • Remove the drain bolt with a 17mm socket wrench, and completely drain the oil.
  7. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 7 단계, 이미지 1/1
    • Remove the oil filter with a 45mm oil filter socket.
  8. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 8 단계, 이미지 1/3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 8 단계, 이미지 2/3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 8 단계, 이미지 3/3
    • Replace the drain bolt with a new drain bolt gasket (crush washer); Honda Washer, Drain Plug (14MM) 94109-14000. Use the 17mm socket wrench to tighten.
  9. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 9 단계, 이미지 1/2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 9 단계, 이미지 2/2
    • Install the new filter in place of the old filter. Hand tighten instead of using the oil filter wrench.
  10. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 10 단계, 이미지 1/2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 10 단계, 이미지 2/2
    • Place the medium funnel and add new 0W-20 full synthetic engine oil. Add 4.2 quarts of oil.
  11. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 11 단계, 이미지 1/1
    • Replace the oil cap.
  12. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 12 단계, 이미지 1/1
    • Start the vehicle, and check for any leaks around the oil filter and oil drain plug.
    • Stop the vehicle and let the engine rest for 5 minutes.
  13. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 13 단계, 이미지 1/3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 13 단계, 이미지 2/3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 13 단계, 이미지 3/3
    • Use the dip stick to double check oil level and add more if needed.
    • Make sure the oil level is in between the low and high marks on the dip stick. Replace the dip stick and close the hood.
    • Reset the oil life in the maintenance section of the vehicle computer.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Clay Casey
회원 가입일: 06/12/20
325 평판
안내서 1개 작성함
University of Memphis, Team S1-G2, Lane Summer 2020 University of Memphis, Team S1-G2, Lane Summer 2020 회원
UM-LANE-SU20S1G2
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 25
7일 전: 155
30일 전: 717
전체 시간: 21,823
