주요 콘텐츠로 건너뛰기
2012-2015 Honda Civic Honda Key Battery Replacement
필요한 것
  1. 2012-2015 Honda Civic Honda Key Battery Replacement, Honda Key Battery: 1 단계, 이미지 1/2 2012-2015 Honda Civic Honda Key Battery Replacement, Honda Key Battery: 1 단계, 이미지 2/2
    • Lay the key down so that the Honda symbol is facing upward.
    • Use a Phillips #0 screwdriver to remove one screw.
  2. 2012-2015 Honda Civic Honda Key Battery Replacement, Pry the cover off: 2 단계, 이미지 1/2 2012-2015 Honda Civic Honda Key Battery Replacement, Pry the cover off: 2 단계, 이미지 2/2
    • Insert the flat end of your spudger into the notch in the side of the key/remote.
    • Pry the key remote apart to remove the cover.
  3. 2012-2015 Honda Civic Honda Key Battery Replacement, Replace the battery: 3 단계, 이미지 1/1
    • Before you remove the battery, note which side faces up (+ or -). You should install your replacement the same way.
    • Remove the battery.
    • Your key may contain either a CR1616 or CR1620 battery. In some cases, either type will work, but for the best results, replace it with the same kind of battery that originally came with your key.
    • Install your matching new battery in the same orientation as the original.
  4. 2012-2015 Honda Civic Honda Key Battery Replacement: 4 단계, 이미지 1/1
    • Place the two halves of the remote cover back together.
    • Press the unlock or lock buttons to make sure the remote is working.
    • Place the screw into the hole and tighten with a Phillips #0 screwdriver.
결론
다른 18명이 해당 안내서를 완성하였습니다.
monica
회원 가입일: 03/22/15
421 평판
안내서 1개 작성함
Baylor, Team 5-7, Williams Spring 2015 Baylor, Team 5-7, Williams Spring 2015 회원
BU-WILLIAMS-S15S5G7
4 회원들
안내서 9개 작성하였습니다
댓글 26개
The original battery in my 2012 Honda Civic Key is a Panasonic CR1616, not a CR1620. I bought an Energizer CR1620, and it was too thick.
Harry - 답글
This isn't the same key remote that I have for my 2015 Civic Si (Sedan). Mine is more square shaped and the key is removable from the inside of the device. It also has no apparent opening-point anywhere around it. The only spot I would consider a possible entry point would be where the key is removed.
Robert - 답글
Robert;
Yes, once the key is removed it is just a matter prying it apart from between the two ears that stick up from the center. A fairly thick flat-bladed screw driver will do it (i used the handle end of a tweezer that was handy). This takes a CR2032 battery, (3) volt, very commonly found. There are two little tabs holding it in, plus (+) side up. Just snap it all back together. Voila.
arlen
Arlen Kerbaugh - 답글
Thank you very helpful!!!
inakwana waka -
댓글 쓰기
조회 통계:
24 시간 전: 89
7일 전: 659
30일 전: 2,882
전체 시간: 350,836
