소개
Use this guide to replace a 2012-2016 Honda Civic key remote battery.
필요한 것
Lay the key down so that the Honda symbol is facing upward.
Use a Phillips #0 screwdriver to remove one screw.
Insert the flat end of your spudger into the notch in the side of the key/remote.
Pry the key remote apart to remove the cover.
Before you remove the battery, note which side faces up (+ or -). You should install your replacement the same way.
Remove the battery.
Install your matching new battery in the same orientation as the original.
다른 18명이 해당 안내서를 완성하였습니다.
댓글 26개
The original battery in my 2012 Honda Civic Key is a Panasonic CR1616, not a CR1620. I bought an Energizer CR1620, and it was too thick.
Thanks, Harry!
This isn't the same key remote that I have for my 2015 Civic Si (Sedan). Mine is more square shaped and the key is removable from the inside of the device. It also has no apparent opening-point anywhere around it. The only spot I would consider a possible entry point would be where the key is removed.
Robert;
Yes, once the key is removed it is just a matter prying it apart from between the two ears that stick up from the center. A fairly thick flat-bladed screw driver will do it (i used the handle end of a tweezer that was handy). This takes a CR2032 battery, (3) volt, very commonly found. There are two little tabs holding it in, plus (+) side up. Just snap it all back together. Voila.
arlen
Thank you very helpful!!!
