주요 콘텐츠로 건너뛰기
2012 Acura TSX Cabin Air Filter Replacement
필요한 것
  1. 2012 Acura TSX Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 1/2 2012 Acura TSX Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 2/2
    • Open the glove compartment.
  2. 2012 Acura TSX Cabin Air Filter Replacement: 2 단계, 이미지 1/3 2012 Acura TSX Cabin Air Filter Replacement: 2 단계, 이미지 2/3 2012 Acura TSX Cabin Air Filter Replacement: 2 단계, 이미지 3/3
    • Grab the plastic shelf inside the glove compartment and pull it towards you.
    • The rack may not come off first try, but keep pulling until it eventually comes out.
  3. 2012 Acura TSX Cabin Air Filter Replacement: 3 단계, 이미지 1/3 2012 Acura TSX Cabin Air Filter Replacement: 3 단계, 이미지 2/3 2012 Acura TSX Cabin Air Filter Replacement: 3 단계, 이미지 3/3
    • Find the two clamps on the left and right sides of the cover and with one or two hands, push the clamps inwards and pull out the cover, showing the frame that holds the cabin air filter.
  4. 2012 Acura TSX Cabin Air Filter Replacement: 4 단계, 이미지 1/3 2012 Acura TSX Cabin Air Filter Replacement: 4 단계, 이미지 2/3 2012 Acura TSX Cabin Air Filter Replacement: 4 단계, 이미지 3/3
    • Locate the clips on the left and right sides of the frame.
    • Push the clips inwards and pull until the frame comes out.
  5. 2012 Acura TSX Cabin Air Filter Replacement: 5 단계, 이미지 1/3 2012 Acura TSX Cabin Air Filter Replacement: 5 단계, 이미지 2/3 2012 Acura TSX Cabin Air Filter Replacement: 5 단계, 이미지 3/3
    • Remove the cabin air filter by lifting it.
  6. 2012 Acura TSX Cabin Air Filter Replacement: 6 단계, 이미지 1/3 2012 Acura TSX Cabin Air Filter Replacement: 6 단계, 이미지 2/3 2012 Acura TSX Cabin Air Filter Replacement: 6 단계, 이미지 3/3
    • Discard the old cabin air filter and place the new one on the frame
    • To properly place the cabin air filter, we must align the gaps on the left and right sides of the cabin air filter with the sides left and right side of the plastic chassis.
  7. 2012 Acura TSX Cabin Air Filter Replacement: 7 단계, 이미지 1/3 2012 Acura TSX Cabin Air Filter Replacement: 7 단계, 이미지 2/3 2012 Acura TSX Cabin Air Filter Replacement: 7 단계, 이미지 3/3
    • You are good to go if the filter looks like this first image. If there are still significant gaps on the left and right side of the cabin air filter, proceed to correctly fit the cabin air filter onto the frame.
    • Finish by placing the new cabin air filter with the frame together into the car.
결론
Alan Rodriguez
회원 가입일: 08/22/22
145 평판
안내서 1개 작성함
CSU Los Angeles, Team 3-56, Briggs Fall 2022 CSU Los Angeles, Team 3-56, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S3G56
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 39
전체 시간: 426
