주요 콘텐츠로 건너뛰기
2012 BMW 3 Series Windshield Wiper Replacement
필요한 것
  1. 2012 BMW 3 Series Windshield Wiper Replacement, Windshield Wiper: 1 단계, 이미지 1/2 2012 BMW 3 Series Windshield Wiper Replacement, Windshield Wiper: 1 단계, 이미지 2/2
    • To begin, open the hood and make sure the broken wiper's body is completely positioned on the hood.
    • This is done to prevent scratches from developing throughout the repair process.
  2. 2012 BMW 3 Series Windshield Wiper Replacement: 2 단계, 이미지 1/2 2012 BMW 3 Series Windshield Wiper Replacement: 2 단계, 이미지 2/2
    • Use your fingers to pop the cover off that holds the wiper in place.
  3. 2012 BMW 3 Series Windshield Wiper Replacement: 3 단계, 이미지 1/2 2012 BMW 3 Series Windshield Wiper Replacement: 3 단계, 이미지 2/2
    • Use a back and forth motion to carefully remove the wiper blade from the wiper arm. and then pull it out.
  4. 2012 BMW 3 Series Windshield Wiper Replacement: 4 단계, 이미지 1/2 2012 BMW 3 Series Windshield Wiper Replacement: 4 단계, 이미지 2/2
    • Install the replacement wiper so that the slightly bent angle side faces the vehicle.
  5. 2012 BMW 3 Series Windshield Wiper Replacement: 5 단계, 이미지 1/2 2012 BMW 3 Series Windshield Wiper Replacement: 5 단계, 이미지 2/2
    • Check that the screw is aligned with the hole.
    • With a little pressure, slowly slide the new wiper into place.
  6. 2012 BMW 3 Series Windshield Wiper Replacement: 6 단계, 이미지 1/2 2012 BMW 3 Series Windshield Wiper Replacement: 6 단계, 이미지 2/2
    • Once it is positioned correctly, lock the cover to keep the blade in place.
    • If you hear a click, you will know you have succeeded.
    • Lower the windshield wiper carefully onto the windshield.
  7. 2012 BMW 3 Series Windshield Wiper Replacement: 7 단계, 이미지 1/1
    • Finally, test your wiper blades by spraying water or windshield wiper cleaner over your windshield and turning on the wipers.
    • You are done if they are wiping properly. If they appear to be loose, make sure they are securely attached before driving again.
결론
Hafsa Yusuf
회원 가입일: 09/14/21
145 평판
안내서 1개 작성함
York University, Team R-30, Melo-Thaiss Winter 2022 York University, Team R-30, Melo-Thaiss Winter 2022 회원
YORK-MELO-THAISS-W22SRG30
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 42
전체 시간: 1,020
