주요 콘텐츠로 건너뛰기
2012 Ford Fusion Headlight Replacement
필요한 것
  1. 2012 Ford Fusion Headlight Replacement, Headlight: 1 단계, 이미지 1개 중 1개
    • Locate the hood latch and pull it to open
  2. 2012 Ford Fusion Headlight Replacement: 2 단계, 이미지 3개 중 1개 2012 Ford Fusion Headlight Replacement: 2 단계, 이미지 3개 중 2개 2012 Ford Fusion Headlight Replacement: 2 단계, 이미지 3개 중 3개
    • The front hood will open and be caught by a saftey latch. Run fingers under the hood and push the latch to the left to open the hood completely
  3. 2012 Ford Fusion Headlight Replacement: 3 단계, 이미지 2개 중 1개 2012 Ford Fusion Headlight Replacement: 3 단계, 이미지 2개 중 2개
    • Hold up the hood with the hood support rod
  4. 2012 Ford Fusion Headlight Replacement: 4 단계, 이미지 2개 중 1개 2012 Ford Fusion Headlight Replacement: 4 단계, 이미지 2개 중 2개
    • Remove negative terminal from the battery using a 10mm socket. Remove the bolt that is holding the negative terminal and pull terminal off the battery.
  5. 2012 Ford Fusion Headlight Replacement: 5 단계, 이미지 2개 중 1개 2012 Ford Fusion Headlight Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the headlight bulb in the front of the car under the hood and twist off the cap covering the headlight bulb
  6. 2012 Ford Fusion Headlight Replacement: 6 단계, 이미지 2개 중 1개 2012 Ford Fusion Headlight Replacement: 6 단계, 이미지 2개 중 2개
    • twist the housing to the light bulb and pull it out
  7. 2012 Ford Fusion Headlight Replacement: 7 단계, 이미지 2개 중 1개 2012 Ford Fusion Headlight Replacement: 7 단계, 이미지 2개 중 2개
    • unclip the light bulb from the housing latch and replace light bulb
결론
To reassemble your headlight, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Angelica
회원 가입일: 02/26/19
226 평판
안내서 1개를 작성함
5가이드 댓글
What about the left side?
destroyer2040 - 답글
So this was completely useless. You only showed the one semi easy to reach bulb whereas the rest look like the front of the car needs to be disassembled to reach. Why even post this useless junk?
Joe - 답글
I agree with both previous comments. your efforts are INCOMPLETE.
What about the left side(PASSENGER  SIDE THAT IS)
You only showed the one semi easy to reach(DRIVER’S SIDE, THAT IS)
Al Moghtader - 답글
Yea this guide is incomplete and not helpful.
John Fisher - 답글
what years do the head lite assy match with on 2012 ford fusion sle
gordon r bissell - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 26
지난 30일: 108
전체 시간: 15,262
