주요 콘텐츠로 건너뛰기
2013-2017 Ford Escape Key Fob Battery Replacement
필요한 것
  1. 2013-2017 Ford Escape Key Fob Battery  Replacement, 2013-2017 Ford Escape Key Fob Battery: 1 단계, 이미지 1/1
    • Slide over the key release switch on the back of the fob.
  2. 2013-2017 Ford Escape Key Fob Battery  Replacement: 2 단계, 이미지 1/1
    • Remove the metal ignition key from the fob.
  3. 2013-2017 Ford Escape Key Fob Battery  Replacement: 3 단계, 이미지 1/1
    • Insert the ignition key in the notch on the left with the FORD logo facing upward.
  4. 2013-2017 Ford Escape Key Fob Battery  Replacement: 4 단계, 이미지 1/2 2013-2017 Ford Escape Key Fob Battery  Replacement: 4 단계, 이미지 2/2
    • Gently remove the back cover of the key fob.
  5. 2013-2017 Ford Escape Key Fob Battery  Replacement: 5 단계, 이미지 1/2 2013-2017 Ford Escape Key Fob Battery  Replacement: 5 단계, 이미지 2/2
    • Remove the old battery using the ignition key.
  6. 2013-2017 Ford Escape Key Fob Battery  Replacement: 6 단계, 이미지 1/1
    • Insert the new battery with “+” facing downward and the “-“ facing upward.
결론
To reassemble your device, replace the back cover to the key fob and secure firmly.
다른 36명이 해당 안내서를 완성하였습니다.
Katelyn Olkowski
회원 가입일: 02/20/18
565 평판
안내서 1개 작성함
댓글 16개
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
Colonel nom de guerre - 답글
How can you find a replacement ignition key? I have the fob, but the ignition key is nowhere to be found, didn't notice it missing on our spare from the dealer until recently.
RU 1979 - 답글
You have to pay for the key it doesn't come with it
datingsas -
Excellent guide, Thanks for the details
Mihael Patrick - 답글
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
dingdong406 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 19
7일 전: 191
30일 전: 892
전체 시간: 170,588
