주요 콘텐츠로 건너뛰기
2013-2017 Ford Escape Schlüsselbatterie ersetzen
필요한 것
  1. 2013-2017 Ford Escape Schlüsselbatterie ersetzen, 2013-2017 Ford Escape Schlüsselbatterie: 1 단계, 이미지 1/1
    • Den Knopf für die Schlüsselfreigabe verschieben.
  2. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: 2 단계, 이미지 1/1
    • Den Metallschlüssel aus dem Gehäuse ziehen
  3. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: 3 단계, 이미지 1/1
    • Den Metallschlüssel in die Einkerbung auf der linken Seite drücken. Der Schlüssel sollte mit dem Ford Logo nach oben zeigen
  4. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: 4 단계, 이미지 1/2 2013-2017 Ford Escape Schlüsselbatterie ersetzen: 4 단계, 이미지 2/2
    • Vorsichtig die Rückschale des Schlüssels abheben
  5. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: 5 단계, 이미지 1/2 2013-2017 Ford Escape Schlüsselbatterie ersetzen: 5 단계, 이미지 2/2
    • Die alte Batterie mit dem Metallschlüssel herausholen
  6. 2013-2017 Ford Escape Schlüsselbatterie ersetzen: 6 단계, 이미지 1/1
    • Die neue Batterie mit "+" nach unten und "-" nach oben einlegen.
결론
Um den Schlüssel wieder zusammen zu setzen, einfach die Rückschale wieder auf den Schlüssel drücken.
다른 36명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en de
100%
Paku83님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Katelyn Olkowski
회원 가입일: 02/20/18
565 평판
안내서 1개 작성함
댓글 16개
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
Colonel nom de guerre - 답글
How can you find a replacement ignition key? I have the fob, but the ignition key is nowhere to be found, didn't notice it missing on our spare from the dealer until recently.
RU 1979 - 답글
You have to pay for the key it doesn't come with it
datingsas -
Excellent guide, Thanks for the details
Mihael Patrick - 답글
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
dingdong406 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 21
7일 전: 193
30일 전: 984
전체 시간: 168,899
