주요 콘텐츠로 건너뛰기
2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement
필요한 것
  1. 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement, Rear Tail Light Assembly: 1 단계, 이미지 1/2 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement, Rear Tail Light Assembly: 1 단계, 이미지 2/2
    • Pull the trunk release lever or hold the trunk release button on the remote to open the trunk.
    • The trunk release lever is located on the left side of the driver's side floor board.
  2. 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 2 단계, 이미지 1/3 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 2 단계, 이미지 2/3 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 2 단계, 이미지 3/3
    • Remove the plastic fasteners for the trunk interior trim using the fastener removal tool.
    • Pull the clips out when the fastener has been loosened enough.
    • The fastener in the last image has a hook that goes behind it.
  3. 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 3 단계, 이미지 1/2 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 3 단계, 이미지 2/2
    • Remove the four 8mm bolts using the socket wrench.
  4. 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 4 단계, 이미지 1/1
    • Push the tail light assembly out from the inside to unclip it.
    • Push the tail light assembly in the direction that the arrow faces. You may have to push firmly or slightly wiggle the assembly side to side, if it does not immediately come out.
    • Be careful not to cut yourself or any wires on any metal edges.
  5. 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 5 단계, 이미지 1/2 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 5 단계, 이미지 2/2
    • Remove each of the four connectors from the tail light assembly.
    • Do not worry about remembering the connection spots as each male connector has a unique shape corresponding to a female connector.
    • Do not pull hard on the wiring harness when disconnecting the connectors as it will damage the harness and potentially electrocute your hands.
  6. 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 6 단계, 이미지 1/3 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 6 단계, 이미지 2/3 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 6 단계, 이미지 3/3
    • Plug the four connectors into their corresponding ports of the replacement tail light assembly.
  7. 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 7 단계, 이미지 1/1
    • Push the replacement tail light assembly into its original position until it clicks.
  8. 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 8 단계, 이미지 1/2 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 8 단계, 이미지 2/2
    • Tighten the 8mm nuts that were removed during Step 3 using the 8mm socket wrench.
  9. 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 9 단계, 이미지 1/3 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 9 단계, 이미지 2/3 2013-2017 Honda Accord Coupe Rear Tail Light Assembly Replacement: 9 단계, 이미지 3/3
    • Reattach the plastic fasteners that were removed from the trunk interior in Step 2.
    • The fastener tool is not needed to reattach the fasteners. Simply press them back into place with your thumb until they click into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Stetson Wallace
회원 가입일: 02/22/22
190 평판
안내서 1개 작성함
University of North Texas, Team 1-1, Raign Spring 2022 University of North Texas, Team 1-1, Raign Spring 2022 회원
UNT-RAIGN-S22S1G1
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 74
전체 시간: 2,276
