소개
This guide will take you through how to swap out the air filter in your 2013-2016 Scion Frs or Toyota gt86. Dirtry air filter can cause your car to lose power and gas milage. The dealerships recomend to replace your filter every 15,000-30,000 miles, depending on the driving conditions. It will take you about 5-10 minutes and won't require any tools.
필요한 것
Pull the handle located near the driver's left leg to unlock the hood.
Pull the secondary latch located to the right of the emblem.
Prop up the hood.
거의 끝나갑니다!
Now that the new filter is installed, you're good to go.
결론
