주요 콘텐츠로 건너뛰기
2013-2016 Scion FRS (Toyota gt86) Engine Air Filter Replacement
필요한 것
  1. 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement, Engine Air Filter: 1 단계, 이미지 1/3 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement, Engine Air Filter: 1 단계, 이미지 2/3 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement, Engine Air Filter: 1 단계, 이미지 3/3
    • Pull the handle located near the driver's left leg to unlock the hood.
    • Pull the secondary latch located to the right of the emblem.
    • Prop up the hood.
    • Make sure you're not working in a high wind area, as that might blow the hood backward and damage your vehicle.
  2. 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: 2 단계, 이미지 1/1
    • Locate the air filter box, which can be found to the front right of the car.
  3. 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: 3 단계, 이미지 1/3 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: 3 단계, 이미지 2/3 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: 3 단계, 이미지 3/3
    • Pull the metal clips up from the top. They will pop out.
  4. 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: 4 단계, 이미지 1/3 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: 4 단계, 이미지 2/3 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: 4 단계, 이미지 3/3
    • Grab the back of the box and pull it towards the top.
    • To pull out the air-filter, simply pull it away from the car and lift up.
  5. 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: 5 단계, 이미지 1/1
    • Repeat the process in reverse to install the air filter.
    • Make sure that the tabs on the filter are on the bottom.
  6. 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: 6 단계, 이미지 1/1
    • Line up the little pins on the cover of the box with the base of the box in order to close it.
    • Clip the pins back in and you're done!
결론
Now that the new filter is installed, you're good to go.
Mark Symonenko
회원 가입일: 09/25/18
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 31
전체 시간: 2,672
