주요 콘텐츠로 건너뛰기
2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement
필요한 것
  1. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: 1 단계, 이미지 1/3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: 1 단계, 이미지 2/3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement, Camera: 1 단계, 이미지 3/3
    • Mount the new camera in the space provided.
    • The camera routes through the bumper of the car and not the license plate.
  2. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 2 단계, 이미지 1/3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 2 단계, 이미지 2/3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 2 단계, 이미지 3/3
    • Run the new wires through the holes provided, and cover with electrical tape.
    • The new cords will simply connect where the faulty wires were removed.
  3. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 3 단계, 이미지 1/3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 3 단계, 이미지 2/3 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 3 단계, 이미지 3/3
    • Coordinate the colored wires to keep the repair simple. Match the new wires to the existing wires through the splitter. Use a wire splitter to expose the wire.
    • Then simply connect the wires to the wires for reverse light.
  4. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 4 단계, 이미지 1/1
    • The green wire is the camera connection or positive wire and the black is the ground.
    • This line should already be connected correctly because you should have only switched wires that connected to the camera.
  5. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 5 단계, 이미지 1/1
    • Make sure that the reverse light is working properly when the car is in reverse.
  6. 2013-2015 Chevrolet Malibu Factory BackUp Camera Replacement: 6 단계, 이미지 1/1
    • Make sure the display is clear and working properly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
LaTonya
회원 가입일: 05/31/17
167 평판
안내서 1개 작성함
댓글 2개
The photos you show in steps 2 & 3 - is that the trunk only?
jrselinger24 - 답글
Hello. I am trying to replace my camera. But not sure how to remove it or where to buy a replacement.
Jonathan Anderson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 49
30일 전: 168
전체 시간: 13,134
