주요 콘텐츠로 건너뛰기
2013 Ford Focus SE  Stereo Replacement
Jack Ramsay
Jack Ramsay2 다른 기여자
최종 수정일 April 11, 2023
9 분
조정
Prior to completing this guide, refer to the troubleshooting link at the bottom of the introduction and if issues still occur, continue with this guide.
The Ford Focus SE is an automatic hatchback car produced in 2013. The stereo component is used for blue-tooth connectivity that allows music and phone operations from an external device. The stereo also has a built in CD compartment to play music.
The stereo component of the car would sometimes produce loud pops or static noise from the speakers on the door panels. If your Ford Focus SE stereo is producing loud static noises or is not working properly, this guide will show you how to replace the stereo in the car without having to go to a mechanic or dealership to install it.
Before starting on this guide make sure the car is completely off the entire time and refer to the links below for assistance outside of this guide.
For troubleshooting the stereo, refer to this link:
https://owner.ford.com/support/how-tos/s...
For connecting your phone to the “SYNC-Phone” option, refer to this link :
필요한 것
도구
  1. 2013 Ford Focus SE  Stereo Replacement, Stereo: 1 단계, 이미지 3개 중 1개 2013 Ford Focus SE  Stereo Replacement, Stereo: 1 단계, 이미지 3개 중 2개 2013 Ford Focus SE  Stereo Replacement, Stereo: 1 단계, 이미지 3개 중 3개
    • Unlock the car using the unlock button on the key fob or inserting the key into the door.
    • Open the car door.
    • The stereo panel is attached to the center dashboard.
  2. 2013 Ford Focus SE  Stereo Replacement: 2 단계, 이미지 3개 중 1개 2013 Ford Focus SE  Stereo Replacement: 2 단계, 이미지 3개 중 2개 2013 Ford Focus SE  Stereo Replacement: 2 단계, 이미지 3개 중 3개
    • Use the T20 Torx screwdriver to remove the two 19 mm torx screws under the lip of the stereo panel.
    • Set aside these screws for reassembly.
  3. 2013 Ford Focus SE  Stereo Replacement: 3 단계, 이미지 3개 중 1개 2013 Ford Focus SE  Stereo Replacement: 3 단계, 이미지 3개 중 2개 2013 Ford Focus SE  Stereo Replacement: 3 단계, 이미지 3개 중 3개
    • Carefully lift the panel up and out.
    • There is a wire attached to the back of panel.
    • Unplug the stereo connector from the panel and set aside the panel.
    • There are two Torx screw's attached to the stereo box.
  4. 2013 Ford Focus SE  Stereo Replacement: 4 단계, 이미지 3개 중 1개 2013 Ford Focus SE  Stereo Replacement: 4 단계, 이미지 3개 중 2개 2013 Ford Focus SE  Stereo Replacement: 4 단계, 이미지 3개 중 3개
    • Use the Torx T20 screwdriver to unscrew the top left and top right 19 mm screws.
    • Slowly remove the stereo box from the screw connectors.
  5. 2013 Ford Focus SE  Stereo Replacement: 5 단계, 이미지 3개 중 1개 2013 Ford Focus SE  Stereo Replacement: 5 단계, 이미지 3개 중 2개 2013 Ford Focus SE  Stereo Replacement: 5 단계, 이미지 3개 중 3개
    • Once the stereo box is removed from connectors, there will be 3 cords attached to the box.
    • The yellow wire will require some force to open because it serves as the power connector for the stereo.
    • Carefully push down on the clamp to disconnect the yellow wire on the far left of the box.
    • Push down on the clamps in the middle to remove the middle wire.
    • Push down on the clamps in the middle to remove the far right wire.
  6. 2013 Ford Focus SE  Stereo Replacement: 6 단계, 이미지 2개 중 1개 2013 Ford Focus SE  Stereo Replacement: 6 단계, 이미지 2개 중 2개
    • Once the wires are disconnected, safely remove the stereo box.
    • In order to proceed to the next step, reassemble the new stereo by following the steps in reverse order.
  7. 2013 Ford Focus SE  Stereo Replacement: 7 단계, 이미지 3개 중 1개 2013 Ford Focus SE  Stereo Replacement: 7 단계, 이미지 3개 중 2개 2013 Ford Focus SE  Stereo Replacement: 7 단계, 이미지 3개 중 3개
    • It is safe to turn the car on once the stereo has been reinstalled.
    • Press the center stereo button to turn the stereo on.
    • Press the menu button.
    • Press the OK button on SYNC-Media.
  8. 2013 Ford Focus SE  Stereo Replacement: 8 단계, 이미지 2개 중 1개 2013 Ford Focus SE  Stereo Replacement: 8 단계, 이미지 2개 중 2개
    • Use the arrow buttons on the stereo panel to navigate to the " Bluetooth Device" page.
    • Press OK on the " Bluetooth Device" page.
    • Navigate to the "Add Bluetooth Device" page using the arrow buttons and press OK.
    • Follow on screen prompt to connect to Bluetooth.
    • Refer to the introduction for a guide on how to connect to SYNC-Phone.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jack Ramsay
회원 가입일: 08/25/20
292 평판
안내서 1개를 작성함
댓글 4개
Great instructions, but the first step for how to remove the cover over the two torques screws is missing. Would really like to know how to remove that cover.
Todd - 답글
Why have the instructions been edited, yet my simple, specific question has not been addressed?
Todd - 답글
Todd, you just have to stick a small flat head in any of the 4 inserts and mine popped right out.
Alex Hedbany -
My question is, does the replacement radio need any type of dealership reprogramming or is it just plug and play?
Alex Hedbany - 답글
댓글 쓰기
조회 통계:
지난 24시간: 30
지난 7일: 197
지난 30일: 424
전체 시간: 12,184
