주요 콘텐츠로 건너뛰기
2013 Honda Accord Headlight Replacement
필요한 것
  1. 2013 Honda Accord Headlight Replacement, Headlight: 1 단계, 이미지 1/3 2013 Honda Accord Headlight Replacement, Headlight: 1 단계, 이미지 2/3 2013 Honda Accord Headlight Replacement, Headlight: 1 단계, 이미지 3/3
    • Turn your vehicle off and put the emergency brake on before you begin the repair.
    • Pull the tab beside the driver side footwell to release the hood.
    • Pull the tab locking the hood upwards.
    • Pull the hood up to its maximum position.
  2. 2013 Honda Accord Headlight Replacement: 2 단계, 이미지 1/2 2013 Honda Accord Headlight Replacement: 2 단계, 이미지 2/2
    • Attach the hood strut in its designated position.
    • The headlight bulbs can be found on the left and the right of the engine bay.
  3. 2013 Honda Accord Headlight Replacement: 3 단계, 이미지 1/2 2013 Honda Accord Headlight Replacement: 3 단계, 이미지 2/2
    • The bulb is located behind the headlight and to the left of the windshield washer reservoir.
  4. 2013 Honda Accord Headlight Replacement: 4 단계, 이미지 1/2 2013 Honda Accord Headlight Replacement: 4 단계, 이미지 2/2
    • Pull the bulb out from the socket.
    • Use a prying tool at the base of the socket to detach the bulb from the holder.
  5. 2013 Honda Accord Headlight Replacement: 5 단계, 이미지 1/3 2013 Honda Accord Headlight Replacement: 5 단계, 이미지 2/3 2013 Honda Accord Headlight Replacement: 5 단계, 이미지 3/3
    • Attach the new LED bulb to the socket.
    • Don't touch the new bulb with your hands or fingers. The oil from your skin can reduce the life of the bulb or cause it to shatter.
    • Place the bulb in the holder and turn it counterclockwise.
    • Once it is firmly in place, it should not budge.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tahsin
회원 가입일: 09/19/22
145 평판
안내서 1개 작성함
York University, Team A-8, Morris Fall 2022 York University, Team A-8, Morris Fall 2022 회원
YORK-MORRIS-F22SAG8
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 54
전체 시간: 2,580
