주요 콘텐츠로 건너뛰기
2013 Lexus IS250 Front Dome Light Replacement
  1. 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: 1 단계, 이미지 1/2 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: 1 단계, 이미지 2/2
    • Open the glasses compartment located near the front dome light. This is usually a straightforward latch or button release.
  2. 2013 Lexus IS250 Front Dome Light Replacement: 2 단계, 이미지 1/3 2013 Lexus IS250 Front Dome Light Replacement: 2 단계, 이미지 2/3 2013 Lexus IS250 Front Dome Light Replacement: 2 단계, 이미지 3/3
    • Locate two housings inisde the compartment and gently pry them open using a flathead screwdriver. Take care not to damage the surrounding plastic.
  3. 2013 Lexus IS250 Front Dome Light Replacement: 3 단계, 이미지 1/3 2013 Lexus IS250 Front Dome Light Replacement: 3 단계, 이미지 2/3 2013 Lexus IS250 Front Dome Light Replacement: 3 단계, 이미지 3/3
    • Utilize a star screwdriver to remove the screws holding the front dome light in place. Ensure a steady hand to prevent any accidental dropping of screws.
  4. 2013 Lexus IS250 Front Dome Light Replacement: 4 단계, 이미지 1/3 2013 Lexus IS250 Front Dome Light Replacement: 4 단계, 이미지 2/3 2013 Lexus IS250 Front Dome Light Replacement: 4 단계, 이미지 3/3
    • With both hands wiggle both sides of the dome. Apply a bit of force at the top to release it from its position. Be cautious to not break the plastic clips securing it.
  5. 2013 Lexus IS250 Front Dome Light Replacement: 5 단계, 이미지 1/3 2013 Lexus IS250 Front Dome Light Replacement: 5 단계, 이미지 2/3 2013 Lexus IS250 Front Dome Light Replacement: 5 단계, 이미지 3/3
    • Inside, youll find two bulbs on both ends. Twist them to unlock and carefully remove.
  6. 2013 Lexus IS250 Front Dome Light Replacement: 6 단계, 이미지 1/2 2013 Lexus IS250 Front Dome Light Replacement: 6 단계, 이미지 2/2
    • Carefully remove bulb. Recommended to use gloves as it can be difficult to get a grip.
  7. 2013 Lexus IS250 Front Dome Light Replacement: 7 단계, 이미지 1/3 2013 Lexus IS250 Front Dome Light Replacement: 7 단계, 이미지 2/3 2013 Lexus IS250 Front Dome Light Replacement: 7 단계, 이미지 3/3
    • Replace these bulbs with LED alternatives, inserting them and securing by twisting.
  8. 2013 Lexus IS250 Front Dome Light Replacement: 8 단계, 이미지 1/1
    • Confirm that the bulbs are functioning by checking if the lights turn on. If not double check the alignment of the bulbs to ensure proper contact.
    • Carefully place the dome back into its original position. Ensure it aligns correctly with the plastic tips. Apply gentle pressure until it clicks back into place.
결론
Christian
회원 가입일: 10/23/23
157 평판
안내서 1개 작성함
CSU Los Angeles, Team 5-3, Kershman Fall 2023 CSU Los Angeles, Team 5-3, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S5G3
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 35
전체 시간: 161
