주요 콘텐츠로 건너뛰기
2013 Lexus IS250 Front Dome Light Replacement
  1. 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: 1 단계, 이미지 2개 중 1개 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: 1 단계, 이미지 2개 중 2개
    • Open the glasses compartment located near the front dome light. This is usually a straightforward latch or button release.
  2. 2013 Lexus IS250 Front Dome Light Replacement: 2 단계, 이미지 3개 중 1개 2013 Lexus IS250 Front Dome Light Replacement: 2 단계, 이미지 3개 중 2개 2013 Lexus IS250 Front Dome Light Replacement: 2 단계, 이미지 3개 중 3개
    • Locate two housings inisde the compartment and gently pry them open using a flathead screwdriver. Take care not to damage the surrounding plastic.
  3. 2013 Lexus IS250 Front Dome Light Replacement: 3 단계, 이미지 3개 중 1개 2013 Lexus IS250 Front Dome Light Replacement: 3 단계, 이미지 3개 중 2개 2013 Lexus IS250 Front Dome Light Replacement: 3 단계, 이미지 3개 중 3개
    • Utilize a star screwdriver to remove the screws holding the front dome light in place. Ensure a steady hand to prevent any accidental dropping of screws.
  4. 2013 Lexus IS250 Front Dome Light Replacement: 4 단계, 이미지 3개 중 1개 2013 Lexus IS250 Front Dome Light Replacement: 4 단계, 이미지 3개 중 2개 2013 Lexus IS250 Front Dome Light Replacement: 4 단계, 이미지 3개 중 3개
    • With both hands wiggle both sides of the dome. Apply a bit of force at the top to release it from its position. Be cautious to not break the plastic clips securing it.
  5. 2013 Lexus IS250 Front Dome Light Replacement: 5 단계, 이미지 3개 중 1개 2013 Lexus IS250 Front Dome Light Replacement: 5 단계, 이미지 3개 중 2개 2013 Lexus IS250 Front Dome Light Replacement: 5 단계, 이미지 3개 중 3개
    • Inside, youll find two bulbs on both ends. Twist them to unlock and carefully remove.
  6. 2013 Lexus IS250 Front Dome Light Replacement: 6 단계, 이미지 2개 중 1개 2013 Lexus IS250 Front Dome Light Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully remove bulb. Recommended to use gloves as it can be difficult to get a grip.
  7. 2013 Lexus IS250 Front Dome Light Replacement: 7 단계, 이미지 3개 중 1개 2013 Lexus IS250 Front Dome Light Replacement: 7 단계, 이미지 3개 중 2개 2013 Lexus IS250 Front Dome Light Replacement: 7 단계, 이미지 3개 중 3개
    • Replace these bulbs with LED alternatives, inserting them and securing by twisting.
  8. 2013 Lexus IS250 Front Dome Light Replacement: 8 단계, 이미지 1개 중 1개
    • Confirm that the bulbs are functioning by checking if the lights turn on. If not double check the alignment of the bulbs to ensure proper contact.
    • Carefully place the dome back into its original position. Ensure it aligns correctly with the plastic tips. Apply gentle pressure until it clicks back into place.
결론
작성자
1다른 기여자 명과 함께
Christian
회원 가입일: 10/23/23
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 29
전체 시간: 592
