주요 콘텐츠로 건너뛰기
2013 Nissan Altima Interior Door Handle Replacement
필요한 것
  1. 2013 Nissan Altima Interior Door Handle Replacement, Interior Door Handle: 1 단계, 이미지 3개 중 1개 2013 Nissan Altima Interior Door Handle Replacement, Interior Door Handle: 1 단계, 이미지 3개 중 2개 2013 Nissan Altima Interior Door Handle Replacement, Interior Door Handle: 1 단계, 이미지 3개 중 3개
    • Use an opening tool or spudger to gently pry open the cover behind the door handle.
    • Use a 10 mm socket to remove the bolt under the handle cap.
  2. 2013 Nissan Altima Interior Door Handle Replacement: 2 단계, 이미지 3개 중 1개 2013 Nissan Altima Interior Door Handle Replacement: 2 단계, 이미지 3개 중 2개 2013 Nissan Altima Interior Door Handle Replacement: 2 단계, 이미지 3개 중 3개
    • Use an opening tool or spudger to pry the window and door lock assembly up and free from the frame.
    • Use a 10 mm socket to remove the single bolt underneath the control assembly.
  3. 2013 Nissan Altima Interior Door Handle Replacement: 3 단계, 이미지 3개 중 1개 2013 Nissan Altima Interior Door Handle Replacement: 3 단계, 이미지 3개 중 2개 2013 Nissan Altima Interior Door Handle Replacement: 3 단계, 이미지 3개 중 3개
    • There is another screw located underneath the long arm panel (to the left of the door handle), unscrew it.
  4. 2013 Nissan Altima Interior Door Handle Replacement: 4 단계, 이미지 1개 중 1개
    • Unhook the cables from the window control panel to take off the door.
  5. 2013 Nissan Altima Interior Door Handle Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the three silver screws directly behind the door handle (Top, left, right).
  6. 2013 Nissan Altima Interior Door Handle Replacement: 6 단계, 이미지 3개 중 1개 2013 Nissan Altima Interior Door Handle Replacement: 6 단계, 이미지 3개 중 2개 2013 Nissan Altima Interior Door Handle Replacement: 6 단계, 이미지 3개 중 3개
    • Unhook the two wires that hook into the unlock/lock mechanisms.
  7. 2013 Nissan Altima Interior Door Handle Replacement: 7 단계, 이미지 2개 중 1개 2013 Nissan Altima Interior Door Handle Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the old door handle.
  8. 2013 Nissan Altima Interior Door Handle Replacement: 8 단계, 이미지 2개 중 1개 2013 Nissan Altima Interior Door Handle Replacement: 8 단계, 이미지 2개 중 2개
    • Place and screw the new handle into place.
  9. 2013 Nissan Altima Interior Door Handle Replacement: 9 단계, 이미지 3개 중 1개 2013 Nissan Altima Interior Door Handle Replacement: 9 단계, 이미지 3개 중 2개 2013 Nissan Altima Interior Door Handle Replacement: 9 단계, 이미지 3개 중 3개
    • Hook the lock/unlock wires back into the door handle. (Handle will not work unless this step is complete.
  10. 2013 Nissan Altima Interior Door Handle Replacement: 10 단계, 이미지 2개 중 1개 2013 Nissan Altima Interior Door Handle Replacement: 10 단계, 이미지 2개 중 2개
    • Plug in the window control panel and place the panel back in its respectful place.
    • The door panel clips should goes into the holes and snap in when in place.
  11. 2013 Nissan Altima Interior Door Handle Replacement: 11 단계, 이미지 3개 중 1개 2013 Nissan Altima Interior Door Handle Replacement: 11 단계, 이미지 3개 중 2개 2013 Nissan Altima Interior Door Handle Replacement: 11 단계, 이미지 3개 중 3개
    • Insert the screw beneath the control panel and the screw to the right of the lock/unlock button.
  12. 2013 Nissan Altima Interior Door Handle Replacement: 12 단계, 이미지 3개 중 1개 2013 Nissan Altima Interior Door Handle Replacement: 12 단계, 이미지 3개 중 2개 2013 Nissan Altima Interior Door Handle Replacement: 12 단계, 이미지 3개 중 3개
    • Next, place both the door arm and window control panel in their place. The arm should snap in while the control panel sits flush in place.
  13. 2013 Nissan Altima Interior Door Handle Replacement: 13 단계, 이미지 3개 중 1개 2013 Nissan Altima Interior Door Handle Replacement: 13 단계, 이미지 3개 중 2개 2013 Nissan Altima Interior Door Handle Replacement: 13 단계, 이미지 3개 중 3개
    • Lastly, place the screw back in its respective place and tighten it with the rachet.
  14. 2013 Nissan Altima Interior Door Handle Replacement: 14 단계, 이미지 2개 중 1개 2013 Nissan Altima Interior Door Handle Replacement: 14 단계, 이미지 2개 중 2개
    • Finishing result: The older interior handle is in my hand, while the new interior handle is in place.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ezzaddin alkabsh
회원 가입일: 09/19/22
229 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 27
지난 30일: 77
전체 시간: 3,094
