주요 콘텐츠로 건너뛰기
2013 Nissan Rogue Key Fob Battery Replacement
필요한 것
  1. 2013 Nissan Rogue Key Fob Battery Replacement, 2013 Nissan Rogue Key Fob Battery: 1 단계, 이미지 2개 중 1개 2013 Nissan Rogue Key Fob Battery Replacement, 2013 Nissan Rogue Key Fob Battery: 1 단계, 이미지 2개 중 2개
    • Slide the small tab on the back of your fob to the left.
    • While holding the tab to the left, pull the metal key out from the top of your fob.
  2. 2013 Nissan Rogue Key Fob Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Insert your opening pick into the small gap between the two halves of the fob and lightly pry until they separate.
  3. 2013 Nissan Rogue Key Fob Battery Replacement: 3 단계, 이미지 3개 중 1개 2013 Nissan Rogue Key Fob Battery Replacement: 3 단계, 이미지 3개 중 2개 2013 Nissan Rogue Key Fob Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Pull the two halves of the fob apart.
    • Remove the two internal housings.
  4. 2013 Nissan Rogue Key Fob Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the battery.
  5. 2013 Nissan Rogue Key Fob Battery Replacement: 5 단계, 이미지 3개 중 1개 2013 Nissan Rogue Key Fob Battery Replacement: 5 단계, 이미지 3개 중 2개 2013 Nissan Rogue Key Fob Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Lightly saturate a cotton swab with 70% isopropyl alcohol and wipe down the inside of the shells and the rubber pad.
    • For any small crevices dip, the toothpick into the alcohol and clean any dirt or debris.
    • Avoid wiping the circuit board and any metal components.
  6. 2013 Nissan Rogue Key Fob Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Once the alcohol is dried, place a new battery into the battery housing with the proper orientation.
  7. 2013 Nissan Rogue Key Fob Battery Replacement: 7 단계, 이미지 3개 중 1개 2013 Nissan Rogue Key Fob Battery Replacement: 7 단계, 이미지 3개 중 2개 2013 Nissan Rogue Key Fob Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Replace the internal components and click the two halves of the fob back together.
  8. 2013 Nissan Rogue Key Fob Battery Replacement: 8 단계, 이미지 2개 중 1개 2013 Nissan Rogue Key Fob Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Slide your key back into its housing.
결론
Your fob should now be fully functional!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Homero Mena Ortiz
회원 가입일: 02/28/22
175 평판
안내서 1개를 작성함
댓글 2개
OMG… I wish I had read this before and attempted to take my key fob apart. I’ve got it all scraped up and ugly from them telling me to use a screwdriver….never mind just do exacty everything this post tells you. I had no problems opening the key fob once I read this article .
Trust me do as this tells you step by step. Just don’t use a screwdriver as another on the www will inform you to do.
Thank you so much for posting this key fob battery replacement info.
Pamela Parker - 답글
Thanks worked perfectly and as stated above don't use a screwdriver I also read that but thank goodness I didn't have one
brandy france - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 58
전체 시간: 4,840
