주요 콘텐츠로 건너뛰기
2013 Nissan Rogue Key Fob Battery Replacement
필요한 것
  1. 2013 Nissan Rogue Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 1/3 2013 Nissan Rogue Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 2/3 2013 Nissan Rogue Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 3/3
    • Remove the key from the keyring by pulling the button on the back of the keyring from right to left while pulling the loop at the top.
  2. 2013 Nissan Rogue Key Fob Battery Replacement: 2 단계, 이미지 1/3 2013 Nissan Rogue Key Fob Battery Replacement: 2 단계, 이미지 2/3 2013 Nissan Rogue Key Fob Battery Replacement: 2 단계, 이미지 3/3
    • Carefully separate the back cover from the rest of the remote.
    • You can use a tool to make this step easier, or you can just do it using your fingers, being very careful.
  3. 2013 Nissan Rogue Key Fob Battery Replacement: 3 단계, 이미지 1/2 2013 Nissan Rogue Key Fob Battery Replacement: 3 단계, 이미지 2/2
    • Carefully remove the individual pieces from inside, one at a time.
    • There are two pieces in total to remove.
  4. 2013 Nissan Rogue Key Fob Battery Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the remote.
    • Put the new battery into the remote and press down firmly to make sure it is secure.
    • Be sure to check that your new battery matches with your old battery.
  5. 2013 Nissan Rogue Key Fob Battery Replacement: 5 단계, 이미지 1/2 2013 Nissan Rogue Key Fob Battery Replacement: 5 단계, 이미지 2/2
    • Carefully snap the back cover onto the rest of the remote.
  6. 2013 Nissan Rogue Key Fob Battery Replacement: 6 단계, 이미지 1/2 2013 Nissan Rogue Key Fob Battery Replacement: 6 단계, 이미지 2/2
    • Put the key back into the remote.
  7. 2013 Nissan Rogue Key Fob Battery Replacement: 7 단계, 이미지 1/1
    • Test the remote key to make sure it works properly.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Hober Granados
회원 가입일: 01/31/22
199 평판
안내서 1개 작성함
CSU Los Angeles, Team Z-25, Briggs Spring 2022 CSU Los Angeles, Team Z-25, Briggs Spring 2022 회원
CSULA-BRIGGS-S22SZG25
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 47
전체 시간: 1,055
