주요 콘텐츠로 건너뛰기
2013 Subaru Impreza WRX Mud Flaps Replacement
필요한 것
  1. 2013 Subaru Impreza WRX Mud Flaps Replacement, Mud Flaps: 1 단계, 이미지 1개 중 1개
    • Always make sure your car is off, the parking break is applied, and you are in a safe area free from other passing cars.
  2. 2013 Subaru Impreza WRX Mud Flaps Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the wheels all the way towards the side you will be working on.
    • This will create easier access to the inside of the wheel well when you are replacing the mud flap.
  3. 2013 Subaru Impreza WRX Mud Flaps Replacement: 3 단계, 이미지 3개 중 1개 2013 Subaru Impreza WRX Mud Flaps Replacement: 3 단계, 이미지 3개 중 2개 2013 Subaru Impreza WRX Mud Flaps Replacement: 3 단계, 이미지 3개 중 3개
    • Start with the front mud flaps.
    • Attach the 7/16th size socket piece to the wrench and begin removing the 7/16th diameter nuts.
  4. 2013 Subaru Impreza WRX Mud Flaps Replacement: 4 단계, 이미지 3개 중 1개 2013 Subaru Impreza WRX Mud Flaps Replacement: 4 단계, 이미지 3개 중 2개 2013 Subaru Impreza WRX Mud Flaps Replacement: 4 단계, 이미지 3개 중 3개
    • Use your Philips Head screwdriver to unscrew the farthest #6 3/4" Stainless Philips Screw.
    • Be careful not to loose the rubber gasket attached to the screw.
  5. 2013 Subaru Impreza WRX Mud Flaps Replacement: 5 단계, 이미지 3개 중 1개 2013 Subaru Impreza WRX Mud Flaps Replacement: 5 단계, 이미지 3개 중 2개 2013 Subaru Impreza WRX Mud Flaps Replacement: 5 단계, 이미지 3개 중 3개
    • Once the old mud flap is removed, grab your new mud flap and reattach it in the same manner as how you removed the old or broken one.
    • Repeat for opposite front mud flap.
  6. 2013 Subaru Impreza WRX Mud Flaps Replacement: 6 단계, 이미지 3개 중 1개 2013 Subaru Impreza WRX Mud Flaps Replacement: 6 단계, 이미지 3개 중 2개 2013 Subaru Impreza WRX Mud Flaps Replacement: 6 단계, 이미지 3개 중 3개
    • For the back two mud flaps you will need to use a slightly different technique due to the limited space you will be working in.
    • Use your hands and the 10mm wrench piece to unbolt the mud flap.
    • Once you have removed the nuts, you can move on to the #6 3/4" Philips Head Screw.
    • This step will be aided by the use of an extra small Philips screwdriver.
  7. 2013 Subaru Impreza WRX Mud Flaps Replacement: 7 단계, 이미지 2개 중 1개 2013 Subaru Impreza WRX Mud Flaps Replacement: 7 단계, 이미지 2개 중 2개
    • Replace both back mud flaps and fasten all pieces back in place.
  8. 2013 Subaru Impreza WRX Mud Flaps Replacement: 8 단계, 이미지 2개 중 1개 2013 Subaru Impreza WRX Mud Flaps Replacement: 8 단계, 이미지 2개 중 2개
    • Make sure the mud flaps are all properly tightened and positioned before driving your car again.
    • Enjoy your brand new mud flaps.
결론
작성자
2다른 기여자 명과 함께
Alex Davis
회원 가입일: 09/29/15
101 평판
안내서 1개를 작성함
Cal Poly, Team 14-3, Green Fall 2015 Cal Poly, Team 14-3, Green Fall 2015 회원
CPSU-GREEN-F15S14G3
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 1,041
