주요 콘텐츠로 건너뛰기
2014-2018 Kia Forte Cabin Air Filter Replacement
  1. 2014-2018 Kia Forte Cabin Air Filter Replacement, Cabin Air Filter: 1 단계, 이미지 1/1
    • Get into the front passenger seat and open the glovebox.
  2. 2014-2018 Kia Forte Cabin Air Filter Replacement: 2 단계, 이미지 1/2 2014-2018 Kia Forte Cabin Air Filter Replacement: 2 단계, 이미지 2/2
    • Remove the 2 circular knobs toward the back of the box (on the left and right sides) and turn them counterclockwise.
  3. 2014-2018 Kia Forte Cabin Air Filter Replacement: 3 단계, 이미지 1/1
    • Remove the arm holding the glove compartment up.
    • It is located on the outer right side of the glove box.
    • Move to the right side of the glovebox and gently pop off the black retaining arm by pulling it towards the right.
  4. 2014-2018 Kia Forte Cabin Air Filter Replacement: 4 단계, 이미지 1/2 2014-2018 Kia Forte Cabin Air Filter Replacement: 4 단계, 이미지 2/2
    • Gently lower the glovebox to the floor.
    • It should hang in the position shown.
  5. 2014-2018 Kia Forte Cabin Air Filter Replacement: 5 단계, 이미지 1/2 2014-2018 Kia Forte Cabin Air Filter Replacement: 5 단계, 이미지 2/2
    • Squeeze the two tabs on the left and right end of the black rectangular casing behind the glovebox and pull the air filter cover off.
  6. 2014-2018 Kia Forte Cabin Air Filter Replacement: 6 단계, 이미지 1/1
    • The air filter should now be exposed. Remove the air filter and replace with a new one.
    • Cabin air flows top to bottom (your old filter should be dirty on the top to illustrate this). Most filters will have an arrow on the side indicating the direction of the airflow, which would be down. Install the new filter accordingly.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Marlon Young
회원 가입일: 03/04/21
205 평판
안내서 1개 작성함
University of Memphis, Team 51-3, Willis Fall 2021 University of Memphis, Team 51-3, Willis Fall 2021 회원
UM-WILLIS-F21S51G3
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 13
7일 전: 100
30일 전: 348
전체 시간: 4,892
