주요 콘텐츠로 건너뛰기
2014 Fiat 500L Rear Windshield Wiper Replacement
필요한 것
  1. 2014 Fiat 500L Rear Windshield Wiper Replacement, Rear Windshield Wiper: 1 단계, 이미지 1/2 2014 Fiat 500L Rear Windshield Wiper Replacement, Rear Windshield Wiper: 1 단계, 이미지 2/2
    • Gently lift the wiper off of the window to begin.
  2. 2014 Fiat 500L Rear Windshield Wiper Replacement: 2 단계, 이미지 1/2 2014 Fiat 500L Rear Windshield Wiper Replacement: 2 단계, 이미지 2/2
    • Using your thumb, push the wiper away from you and out of place. You will hear it click when it is coming off.
  3. 2014 Fiat 500L Rear Windshield Wiper Replacement: 3 단계, 이미지 1/2 2014 Fiat 500L Rear Windshield Wiper Replacement: 3 단계, 이미지 2/2
    • Position the new blade to where it aligns perfectly with the existing wiper arm.
    • There is an ident on the existing wiper arm that the new wiper will fit into.
  4. 2014 Fiat 500L Rear Windshield Wiper Replacement: 4 단계, 이미지 1/3 2014 Fiat 500L Rear Windshield Wiper Replacement: 4 단계, 이미지 2/3 2014 Fiat 500L Rear Windshield Wiper Replacement: 4 단계, 이미지 3/3
    • Place your thumbs on the top of the wiper and your other fingers on the under side of the wiper, to put the wiper into place.
    • You will hear it click when it is locked into place.
  5. 2014 Fiat 500L Rear Windshield Wiper Replacement: 5 단계, 이미지 1/3 2014 Fiat 500L Rear Windshield Wiper Replacement: 5 단계, 이미지 2/3 2014 Fiat 500L Rear Windshield Wiper Replacement: 5 단계, 이미지 3/3
    • Gently rest the wiper against the windshield.
  6. 2014 Fiat 500L Rear Windshield Wiper Replacement: 6 단계, 이미지 1/3 2014 Fiat 500L Rear Windshield Wiper Replacement: 6 단계, 이미지 2/3 2014 Fiat 500L Rear Windshield Wiper Replacement: 6 단계, 이미지 3/3
    • Test out the new wiper.
    • Turn your car on and switch your wiper on. The new blade will fall off of the wiper arm if it is not fully attached. If it is fully attached, the wiper will work successfully.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Sierra Sparre
회원 가입일: 10/30/18
214 평판
안내서 1개 작성함
UC Davis, Team S1-G4, Bender Fall 2018 UC Davis, Team S1-G4, Bender Fall 2018 회원
UCD-BENDER-F18S1G4
3 회원들
안내서 1개 작성하였습니다
댓글 한 개
Thanks for this...all other videos were wrong. I needed the step by step pics.
Sandra Watkins - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 17
전체 시간: 1,916
