주요 콘텐츠로 건너뛰기
2014 Honda CTX 700NA Oil and Oil Filter Replacement
필요한 것
  1. 2014 Honda CTX 700NA Oil and Oil Filter Replacement, Oil and Oil Filter: 1 단계, 이미지 1/2 2014 Honda CTX 700NA Oil and Oil Filter Replacement, Oil and Oil Filter: 1 단계, 이미지 2/2
    • Open the oil reservoir cap, located on the right side of the bike just behind the foot peg.
  2. 2014 Honda CTX 700NA Oil and Oil Filter Replacement: 2 단계, 이미지 1/3 2014 Honda CTX 700NA Oil and Oil Filter Replacement: 2 단계, 이미지 2/3 2014 Honda CTX 700NA Oil and Oil Filter Replacement: 2 단계, 이미지 3/3
    • Using a ratchet and socket, loosen the bolt.
  3. 2014 Honda CTX 700NA Oil and Oil Filter Replacement: 3 단계, 이미지 1/1
    • Once the bolt is removed the oil will drain out. Let all of the oil drain into the oil pan.
    • The drip should be as pictured before screwing the bolt back in.
  4. 2014 Honda CTX 700NA Oil and Oil Filter Replacement: 4 단계, 이미지 1/1
    • Once the bolt is tightly secured back in, unscrew the oil filter.
    • The oil filter is located on the underside of the bike but near the front wheel. If the filter is too tight, use channel lock pliers to get it off.
  5. 2014 Honda CTX 700NA Oil and Oil Filter Replacement: 5 단계, 이미지 1/2 2014 Honda CTX 700NA Oil and Oil Filter Replacement: 5 단계, 이미지 2/2
    • Once the new oil filter is installed, return to the oil reservoir mentioned in step 1. Insert a funnel and begin pouring in new oil, the type of oil required is SAE 10W-30.
    • If you change the oil filter 3.6 quarts will be needed. If you didn't replace the oil filter only 3.3 quarts will be needed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Timothy Riggs
회원 가입일: 03/04/21
169 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 40
30일 전: 200
전체 시간: 3,116
