주요 콘텐츠로 건너뛰기
2014 Infiniti QX50 Windshield Wiper Replacement
필요한 것
  1. 2014 Infiniti QX50 Windshield Wiper Replacement, Windshield Wiper: 1 단계, 이미지 1/2 2014 Infiniti QX50 Windshield Wiper Replacement, Windshield Wiper: 1 단계, 이미지 2/2
    • Go to the driver’s side windshield wiper.
    • Pull the driver's side windshield wiper away from the windshield.
  2. 2014 Infiniti QX50 Windshield Wiper Replacement: 2 단계, 이미지 1/1
    • A tiny clip is holding the blade in place. Push the clip up towards the arm of the wiper and push up.
  3. 2014 Infiniti QX50 Windshield Wiper Replacement: 3 단계, 이미지 1/3 2014 Infiniti QX50 Windshield Wiper Replacement: 3 단계, 이미지 2/3 2014 Infiniti QX50 Windshield Wiper Replacement: 3 단계, 이미지 3/3
    • Completely disconnect the old blade by pushing it a few inches from the arm.
  4. 2014 Infiniti QX50 Windshield Wiper Replacement: 4 단계, 이미지 1/2 2014 Infiniti QX50 Windshield Wiper Replacement: 4 단계, 이미지 2/2
    • Position the new blade so the hook is toward the wiper clip.
    • Place the hook over the top of the attachment and lock the blade into place by pulling it towards the end of the arm.
    • Pressure should be applied so the blade can latch onto the hook.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Marissa
회원 가입일: 03/22/21
133 평판
안내서 1개 작성함
UMass Dartmouth, Team S3-G10, Saloman Spring 2021 UMass Dartmouth, Team S3-G10, Saloman Spring 2021 회원
UMASSD-SALOMAN-S21S3G10
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 18
전체 시간: 350
