주요 콘텐츠로 건너뛰기
2014 Subaru Impreza Hatchback Brake light Replacement
필요한 것
  1. 2014 Subaru Impreza Hatchback Brake light Replacement, Brake Light: 1 단계, 이미지 1개 중 1개
    • Turn off car engine
  2. 2014 Subaru Impreza Hatchback Brake light Replacement: 2 단계, 이미지 1개 중 1개
    • Open the trunk of the car.
  3. 2014 Subaru Impreza Hatchback Brake light Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the both the 2 cm Phillips #3 screws encircled in the image shown with a Phillips #3 screw driver.
    • Unscrewing them will allow you to take out the brake light.
  4. 2014 Subaru Impreza Hatchback Brake light Replacement: 4 단계, 이미지 2개 중 1개 2014 Subaru Impreza Hatchback Brake light Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew both the 2 cm Phillips #3 screws by turning the screwdriver counterclockwise.
  5. 2014 Subaru Impreza Hatchback Brake light Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull the rear light straight back.
  6. 2014 Subaru Impreza Hatchback Brake light Replacement: 6 단계, 이미지 1개 중 1개
    • Upon opening the brake light, you should see three bulbs in total.
    • The brake light is the one on the bottom.
  7. 2014 Subaru Impreza Hatchback Brake light Replacement: 7 단계, 이미지 2개 중 1개 2014 Subaru Impreza Hatchback Brake light Replacement: 7 단계, 이미지 2개 중 2개
    • To remove the brake light, twist the light bulb socket counterclockwise.
    • The bulb should come out as shown in the second image.
  8. 2014 Subaru Impreza Hatchback Brake light Replacement: 8 단계, 이미지 1개 중 1개
    • To remove the bulb, gently pull out the bulb from its connector.
  9. 2014 Subaru Impreza Hatchback Brake light Replacement: 9 단계, 이미지 1개 중 1개
    • Gently insert the new bulb into the connector.
    • Carefully insert the bulb, as the bulb is made of glass it is susceptible to breaking and cutting you if a lot of force is used to insert it in the connector.
  10. 2014 Subaru Impreza Hatchback Brake light Replacement: 10 단계, 이미지 2개 중 1개 2014 Subaru Impreza Hatchback Brake light Replacement: 10 단계, 이미지 2개 중 2개
    • Reinsert the bulb back into its initial position.
    • Gently twist the bulb clockwise to further tighten the bulb.
  11. 2014 Subaru Impreza Hatchback Brake light Replacement: 11 단계, 이미지 1개 중 1개
    • Gently push the rear light cover back into its initial place.
  12. 2014 Subaru Impreza Hatchback Brake light Replacement: 12 단계, 이미지 2개 중 1개 2014 Subaru Impreza Hatchback Brake light Replacement: 12 단계, 이미지 2개 중 2개
    • Reattach both the 2 cm Phillips #3 screws back into their place by screwing them clockwise with your Phillips #3 screwdriver.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Manas Tripathi
회원 가입일: 01/16/23
232 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 6
지난 30일: 50
전체 시간: 2,039
