주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014-Present Kia Sedona Cargo Lamp Bulb Replacement
필요한 것
  1. 2014-Present Kia Sedona Cargo Lamp Bulb Replacement, Remove the lens cover: 1 단계, 이미지 1개 중 1개
    • The lens cover has six plastic tabs that hold it in place.
    • The two rear tabs are larger and harder to unclip.
    댓글 쓰기
  2. 2014-Present Kia Sedona Cargo Lamp Bulb Replacement: 2 단계, 이미지 3개 중 1개 2014-Present Kia Sedona Cargo Lamp Bulb Replacement: 2 단계, 이미지 3개 중 2개 2014-Present Kia Sedona Cargo Lamp Bulb Replacement: 2 단계, 이미지 3개 중 3개
    • These tabs are very stiff. Take your time and be careful not to scratch the plastic. You may need to use a bit of force to unclip these.
    • Insert a metal spudger or a small flathead screwdriver into the front seam near the toggle switch.
    • Pry to release the front tabs.
    • Use a spudger or Jimmy to pry and release the side tabs.
    • Tilt and wiggle the lens cover until the rear tabs release.
    • Remove the lens cover and the gray cover plate behind it.
    댓글 쓰기
  3. 2014-Present Kia Sedona Cargo Lamp Bulb Replacement, Replace the bulb: 3 단계, 이미지 1개 중 1개
    • Pull the bulb out of its two clips and remove it.
    댓글 쓰기
  4. 2014-Present Kia Sedona Cargo Lamp Bulb Replacement, Reinstall the lens cover: 4 단계, 이미지 3개 중 1개 2014-Present Kia Sedona Cargo Lamp Bulb Replacement, Reinstall the lens cover: 4 단계, 이미지 3개 중 2개 2014-Present Kia Sedona Cargo Lamp Bulb Replacement, Reinstall the lens cover: 4 단계, 이미지 3개 중 3개
    • Align and stack the lens cover and gray cover plate together
    • Insert the two larger rear tabs into their recesses.
    • Press the covers into place until all tabs click into place.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
Arthur Shi
회원 가입일: 01/03/18
336,853 평판
안내서 849개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 10
전체 시간: 80
