소개
This guide will show you how you can upgrade the LED headlight for the 2019 Toyota Highlander. The primary purpose of this upgrade is to improve the headlight's brightness which will increase the driver's ability to see at night. The LED light also causes less eyestrain than the OEM headlight.
Before beginning this repair, you must do the following: turn off the car's ignition, place the car in park, and engage the parking brake.
필요한 것
Locate lever to open the hood.
Once the hood is opened, Cover the working area with a towel.
To give yourself more space to work with on the side where the windshield washer reservoir resides, we are going to relocate the nozzle of said reservoir.
Unlock the clip by pressing from both sides of the clip.
While pressing the clip, pull the nozzle up to detach it.
Use a plastic roll to tie the nozzle of the reservoir to the oil cap.
Once the low-beam and high-beam bulbs are installed on both sides, you must now reconnect all of the electrical cables.
Make sure to connect all the cables with the corresponding electrical terminals.
Push on both sides of the connecter until the lock is in the position. (They will make a click sound.)
The upgrade of LED light significantly improved the brightness of the vehicle's headlights. It also makes the car look more modern with clear white light. It is essential to buy the correct light bulb that is compatible with your car. You can search for the make and model including the year of the vehicle; this will help you to find the right LED light.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
hi, if you don't mind, please also provide the light bulb you used for High and low beams. and thank you for your post!
Kevin Chou - 답글
Thanks for the article. Everyone kindly note. Please do NOT forget to adjust the low beams down when installing LEDs. Projector and non projector housings are built for halogen original sources. When installing LEDs the shape of beam is much sharper and blinds other drivers if not adjusted properly. Every vehicle has adjustment screws please ALWAYS adjust your lights down when replacing with LEDs, for any type of car! google how to find the screws and take the time to perform this important step after installing LEDs!
Does this also replace the daytime running lights
