소개
If your 2015 Ford Mustang key fob has lost its ability to start your car, your battery has likely died.
When your key fob battery dies, you lose the ability to start your car, unlock and lock your doors, as well as automatically start your car on those cold mornings. Your car will alert you when your battery is running low, so you should have ample time to get to the store and purchase a replacement battery.
필요한 것
Press down on the button to open the plastic notch.
Remove the back plastic case of the key fob.
다른 2명이 해당 안내서를 완성하였습니다.
