소개
If a key fob battery dies, you can no longer use it to open your car. This can be a hassle, as most modern cars either don’t have a manual way to do so or require a lot of hoops to jump through. Replacing the battery on MINI Cooper key fobs (in this case, a 2015 model, but this should apply to a range of years), though, is a nightmare. The intended way, using the key itself, does not have enough leverage to pry the plastic open without cracking the back plate. This guide goes over how to replace your battery without damaging the back covering.
필요한 것
Using a plastic opening tool, create leverage in the corner of the backplate.
Pry open the corner and move along the seam to the middle while twisting upwards to push the cover upwards.
Repeat on the other side.
다른 한 분이 해당 안내서를 완성하였습니다.
