주요 콘텐츠로 건너뛰기
2015 Mini Cooper Key Fob Battery Replacement
필요한 것
  1. 2015 Mini Cooper Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 2개 중 1개 2015 Mini Cooper Key Fob Battery Replacement, Key Fob Battery: 1 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, create leverage in the corner of the backplate.
    • Pry open the corner and move along the seam to the middle while twisting upwards to push the cover upwards.
    • Repeat on the other side.
  2. 2015 Mini Cooper Key Fob Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Insert a plastic opening tool in the notch on the front of the key fob and pry up the backplate in the center until it pops off.
    • If you hear cracking, make sure both the corners are detached.
  3. 2015 Mini Cooper Key Fob Battery Replacement: 3 단계, 이미지 2개 중 1개 2015 Mini Cooper Key Fob Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Press the silver button on the side of the neck, and pull the key out.
    • Insert the key into the latch on the back of the battery casing, above the slot where it comes out. Pull up and out.
    • If the backing doesn't come out easily, take the key out and try again.
  4. 2015 Mini Cooper Key Fob Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Use your finger to press down and forward on the battery. It should pop out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nathaniel Stringer
회원 가입일: 09/08/21
129 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 38
지난 30일: 185
전체 시간: 10,128
