주요 콘텐츠로 건너뛰기
2015 Nissan Altima Mass Air Flow Sensor Replacement
필요한 것
  1. 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: 1 단계, 이미지 1/3 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: 1 단계, 이미지 2/3 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: 1 단계, 이미지 3/3
    • Open the driver's side door where the hood release is located.
  2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: 2 단계, 이미지 1/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 2 단계, 이미지 2/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 2 단계, 이미지 3/3
    • Connect a scanner by clicking it into the obd2 port.
  3. 2015 Nissan Altima Mass Air Flow Sensor Replacement: 3 단계, 이미지 1/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 3 단계, 이미지 2/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 3 단계, 이미지 3/3
    • Run the code through the scanner.
  4. 2015 Nissan Altima Mass Air Flow Sensor Replacement: 4 단계, 이미지 1/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 4 단계, 이미지 2/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 4 단계, 이미지 3/3
    • Open up the hood latch.
    • Locate front hood holder and lift it up for safety.
  5. 2015 Nissan Altima Mass Air Flow Sensor Replacement: 5 단계, 이미지 1/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 5 단계, 이미지 2/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 5 단계, 이미지 3/3
    • Locate the battery and a positive and negative terminal.
    • The Positive terminal.
    • The Negative terminal.
    • Be careful risk of electrical shock
  6. 2015 Nissan Altima Mass Air Flow Sensor Replacement: 6 단계, 이미지 1/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 6 단계, 이미지 2/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 6 단계, 이미지 3/3
    • Unscrew the positive terminal with a 10mm wrench by turning it counterclockwise.
  7. 2015 Nissan Altima Mass Air Flow Sensor Replacement: 7 단계, 이미지 1/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 7 단계, 이미지 2/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 7 단계, 이미지 3/3
    • Unscrew the negative terminal with a 10mm wrench by turning it counterclockwise.
  8. 2015 Nissan Altima Mass Air Flow Sensor Replacement: 8 단계, 이미지 1/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 8 단계, 이미지 2/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 8 단계, 이미지 3/3
    • Unplug the mass air flow sensor by pushing in the pull tabs and pulling upwards.
  9. 2015 Nissan Altima Mass Air Flow Sensor Replacement: 9 단계, 이미지 1/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 9 단계, 이미지 2/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 9 단계, 이미지 3/3
    • Remove the screws with a Phillips #1 screwdriver by turning them counterclockwise.
  10. 2015 Nissan Altima Mass Air Flow Sensor Replacement: 10 단계, 이미지 1/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 10 단계, 이미지 2/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 10 단계, 이미지 3/3
    • Remove the old sensor by pulling it off and replace with a new one.
  11. 2015 Nissan Altima Mass Air Flow Sensor Replacement: 11 단계, 이미지 1/2 2015 Nissan Altima Mass Air Flow Sensor Replacement: 11 단계, 이미지 2/2
    • Screw back on the screws with a Phillips #1 screwdriver by turning them clockwise.
  12. 2015 Nissan Altima Mass Air Flow Sensor Replacement: 12 단계, 이미지 1/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 12 단계, 이미지 2/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 12 단계, 이미지 3/3
    • Click the sensor in place.
    • Plug in the battery by following steps 6 and 7 in reverse order.
  13. 2015 Nissan Altima Mass Air Flow Sensor Replacement: 13 단계, 이미지 1/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 13 단계, 이미지 2/3 2015 Nissan Altima Mass Air Flow Sensor Replacement: 13 단계, 이미지 3/3
    • Run the scanner again and make sure no check engine light is on and no trouble codes appear.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Jay-z Gonzalez
회원 가입일: 01/23/24
223 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 35
전체 시간: 140
