주요 콘텐츠로 건너뛰기
2016–2020 Honda Civic Tail Light Replacement
필요한 것
  1. 2016–2020 Honda Civic Tail Light Replacement, Tail Light: 1 단계, 이미지 1/2 2016–2020 Honda Civic Tail Light Replacement, Tail Light: 1 단계, 이미지 2/2
    • Unlock and open the trunk of the car.
    • This will allow you to access the screws once it's open.
  2. 2016–2020 Honda Civic Tail Light Replacement: 2 단계, 이미지 1/2 2016–2020 Honda Civic Tail Light Replacement: 2 단계, 이미지 2/2
    • On the exterior of the trunk, take notice of the bolts connected to the tail lights. You will have to work with these.
    • A #8 socket tends to work for most Civics.
  3. 2016–2020 Honda Civic Tail Light Replacement: 3 단계, 이미지 1/3 2016–2020 Honda Civic Tail Light Replacement: 3 단계, 이미지 2/3 2016–2020 Honda Civic Tail Light Replacement: 3 단계, 이미지 3/3
    • Attach the socket to the ratchet and loosen each of the bolts, twisting the ratchet in a counterclockwise direction.
    • Use your hand to secure the tail light so it doesn't fall off once the bolts are loose.
  4. 2016–2020 Honda Civic Tail Light Replacement: 4 단계, 이미지 1/2 2016–2020 Honda Civic Tail Light Replacement: 4 단계, 이미지 2/2
    • Once you have removed the screws, place them somewhere safe because you will be using them to reattach the tail light.
    • If the screws are damaged, you can replace them with two new 8.0 mm Phillips screws.
  5. 2016–2020 Honda Civic Tail Light Replacement: 5 단계, 이미지 1/3 2016–2020 Honda Civic Tail Light Replacement: 5 단계, 이미지 2/3 2016–2020 Honda Civic Tail Light Replacement: 5 단계, 이미지 3/3
    • Pull the tail light out from the rear bumper.
    • Since this could be a tight connection, do not be afraid to use some force or you may need to move it side to side to work it out of the socket.
    • When pulling it out, be careful that you don't rip it out as it is connected to several wires.
  6. 2016–2020 Honda Civic Tail Light Replacement: 6 단계, 이미지 1/3 2016–2020 Honda Civic Tail Light Replacement: 6 단계, 이미지 2/3 2016–2020 Honda Civic Tail Light Replacement: 6 단계, 이미지 3/3
    • Once the tail light is removed, twist the light bulb connector counterclockwise to loosen and then pull it out of the socket.
  7. 2016–2020 Honda Civic Tail Light Replacement: 7 단계, 이미지 1/3 2016–2020 Honda Civic Tail Light Replacement: 7 단계, 이미지 2/3 2016–2020 Honda Civic Tail Light Replacement: 7 단계, 이미지 3/3
    • Put on gloves and pull the bulb out.
    • Pull the bulb out with caution as it can take some force to pull it out.
    • For replacement, a 7740 size bulb is recommended.
  8. 2016–2020 Honda Civic Tail Light Replacement: 8 단계, 이미지 1/3 2016–2020 Honda Civic Tail Light Replacement: 8 단계, 이미지 2/3 2016–2020 Honda Civic Tail Light Replacement: 8 단계, 이미지 3/3
    • Replace the new the light bulb by pushing it back by pushing it back into the socket.
    • It is important to use gloves when doing this as the oils on your hands and fingers will damage the bulb and cause a shorter life for the bulb.
  9. 2016–2020 Honda Civic Tail Light Replacement: 9 단계, 이미지 1/3 2016–2020 Honda Civic Tail Light Replacement: 9 단계, 이미지 2/3 2016–2020 Honda Civic Tail Light Replacement: 9 단계, 이미지 3/3
    • Reattach the tail light.
    • This won’t require much force for it to stay attached.
  10. 2016–2020 Honda Civic Tail Light Replacement: 10 단계, 이미지 1/3 2016–2020 Honda Civic Tail Light Replacement: 10 단계, 이미지 2/3 2016–2020 Honda Civic Tail Light Replacement: 10 단계, 이미지 3/3
    • Use the #8 socket to replace the bolts that secure the tail light.
  11. 2016–2020 Honda Civic Tail Light Replacement: 11 단계, 이미지 1/2 2016–2020 Honda Civic Tail Light Replacement: 11 단계, 이미지 2/2
    • Lightly tighten each bolt in the clockwise direction, alternating between each one in order to avoid one misalignment.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Billy Ouattara
회원 가입일: 04/19/23
229 평판
안내서 1개 작성함
UCD-MORRIS-S23S1G5 UCD-MORRIS-S23S1G5 회원
Community
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 18
30일 전: 95
전체 시간: 1,062
