소개
In this guide you will learn how to replace a low beam headlight bulb for the 10th generation 2016-2021 Honda Civic.
Before beginning the repair, turn off your engine and put on your emergency break.
필요한 것
Pull the latch near the door panel to open the hood (inside the driver's side of the vehicle).
To reconnect the new bulb follow the instructions in reverse order as shown. If the bulb does not turn on make sure to shut off the car before attempting to fix the bulb.
다른 3명이 해당 안내서를 완성하였습니다.
