주요 콘텐츠로 건너뛰기
2016 Jeep Cherokee Windshield Wiper Replacement
필요한 것
  1. 2016 Jeep Cherokee Windshield Wiper Replacement, Windshield Wiper: 1 단계, 이미지 1/3 2016 Jeep Cherokee Windshield Wiper Replacement, Windshield Wiper: 1 단계, 이미지 2/3 2016 Jeep Cherokee Windshield Wiper Replacement, Windshield Wiper: 1 단계, 이미지 3/3
    • If the broken wiper is located on the passenger side, then you will need to purchase an 18-inch wiper.
    • If the damaged wiper is located on the driver side, then you will need a 26-inch wiper.
  2. 2016 Jeep Cherokee Windshield Wiper Replacement: 2 단계, 이미지 1/3 2016 Jeep Cherokee Windshield Wiper Replacement: 2 단계, 이미지 2/3 2016 Jeep Cherokee Windshield Wiper Replacement: 2 단계, 이미지 3/3
    • Most blades are held in place with a tiny clip.
    • Push that clip up, while you are pushing the blade backwards.
  3. 2016 Jeep Cherokee Windshield Wiper Replacement: 3 단계, 이미지 1/1
    • Once you get the blade free from the hook, push the blade down to disconnect it.
  4. 2016 Jeep Cherokee Windshield Wiper Replacement: 4 단계, 이미지 1/3 2016 Jeep Cherokee Windshield Wiper Replacement: 4 단계, 이미지 2/3 2016 Jeep Cherokee Windshield Wiper Replacement: 4 단계, 이미지 3/3
    • After disconnecting the old wiper, position the new blade so that the hook points toward the area where you just detached the old wiper.
  5. 2016 Jeep Cherokee Windshield Wiper Replacement: 5 단계, 이미지 1/1
    • Push the blade towards the arm.
    • Make sure the hook is inside the arm.
    • When completed, you will hear it click, this means that the wiper has been successfully installed.
결승점
mehmet coksurer
회원 가입일: 01/16/23
121 평판
안내서 1개 작성함
York University, Team N-3, Morris Winter 2023 York University, Team N-3, Morris Winter 2023 회원
YORK-MORRIS-W23SNG3
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 31
전체 시간: 327
