주요 콘텐츠로 건너뛰기
2016 Nissan Altima Door Courtesy Lamp Replacement
필요한 것
  1. 2016 Nissan Altima Door Courtesy Lamp Replacement, Door Courtesy Lamp: 1 단계, 이미지 1/2 2016 Nissan Altima Door Courtesy Lamp Replacement, Door Courtesy Lamp: 1 단계, 이미지 2/2
    • Open the door with the faulty courtesy lamp.
    • The courtesy lamp should be located on the bottom of the door.
  2. 2016 Nissan Altima Door Courtesy Lamp Replacement: 2 단계, 이미지 1/2 2016 Nissan Altima Door Courtesy Lamp Replacement: 2 단계, 이미지 2/2
    • Gently pry the lamp housing away from the door using a ESD-safe pry tool.
  3. 2016 Nissan Altima Door Courtesy Lamp Replacement: 3 단계, 이미지 1/1
    • Press down on the white release tab at the far left end of the lamp housing.
  4. 2016 Nissan Altima Door Courtesy Lamp Replacement: 4 단계, 이미지 1/2 2016 Nissan Altima Door Courtesy Lamp Replacement: 4 단계, 이미지 2/2
    • Pull back on the release tab as you press down to separate the lamp housing from the door wiring.
  5. 2016 Nissan Altima Door Courtesy Lamp Replacement: 5 단계, 이미지 1/1
    • Reinsert the wire plug back into the lamp housing.
    • Gently push on the plug until you can no longer insert it further.
    • You should hear an audible click once you've inserted the plug all the way.
  6. 2016 Nissan Altima Door Courtesy Lamp Replacement: 6 단계, 이미지 1/1
    • Turn on the vehicle to verify that the new light works.
    • Look at the bulb to verify that it lights up.
    • You may have to close and re-open the door in order for the light to turn on.
    • There is a chance of electric shock if the wires to your courtesy light are faulty. Avoid touching the light bulb or wires directly.
  7. 2016 Nissan Altima Door Courtesy Lamp Replacement: 7 단계, 이미지 1/1
    • Insert the bottom latches of the lamp into the door socket.
    • Push the top of the lamp into the socket so that the lamp housing is flush with the car door.
    • Reinserting the lamp may require more force than it appears.
결론
If you followed all of the steps correctly your courtesy door lamp should be replaced and functional!
Jay Michalek
회원 가입일: 02/23/23
145 평판
안내서 1개 작성함
University of North Texas, Team 2-9, Raign Spring 2023 University of North Texas, Team 2-9, Raign Spring 2023 회원
UNT-RAIGN-S23S2G9
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 28
전체 시간: 339
