주요 콘텐츠로 건너뛰기
2016 Nissan Altima Key Fob Battery Replacement
필요한 것
  1. 2016 Nissan Altima Key Fob Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 2016 Nissan Altima Key Fob Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 2016 Nissan Altima Key Fob Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Slide the little switch up on the back of the key. While doing so, remove the physical key that is stored inside the fob by pulling away.
  2. 2016 Nissan Altima Key Fob Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Insert a flathead screwdriver or prying tool into the small notch located at the bottom of the key fob.
    • Carefully rotate the flathead counterclockwise to pry apart the two halves of the fob.
  3. 2016 Nissan Altima Key Fob Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Pry out the battery with a flathead to avoid skin contact with electrical components.
    • Make sure to avoid touching the motherboard.
  4. 2016 Nissan Altima Key Fob Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Now carefully place the new battery onto the silver platter.
    • Keep in mind positive side of the battery will be facing downward, while negative side will be facing towards you.
  5. 2016 Nissan Altima Key Fob Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Line up the parts in order to secure the key.
    • Press down until the case makes a "click" sound.
  6. 2016 Nissan Altima Key Fob Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Finally, insert the physical key back into the fob to complete your replacement.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Giovanni Avalos
회원 가입일: 12/06/22
214 평판
안내서 1개를 작성함
댓글 한 개
Great job , thanks . Sent wife info and believe it she figured it out, thanks.
Erik - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 116
전체 시간: 6,119
