소개
This guide demonstrates how to replace the battery in a 2016 Toyota Camry key fob.
Key fobs conveniently unlock and lock your vehicle from a distance with the click of a button. Unfortunately, after 3 or 4 years of continuous use, the battery drains and needs to be replaced.
This is a fairly simple fix that can be completed at home with nothing more than a coin!
필요한 것
Take a coin and wedge it between both halves of the key fob where the keychain notch is. Push against the indent until the fob begins to lift open.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Thanks and nicely done. The small plastic clips that hold the battery can be tricky.
