주요 콘텐츠로 건너뛰기
2017 Honda Accord Headlight Replacement
필요한 것
  1. 2017 Honda Accord Headlight Replacement, Headlight: 1 단계, 이미지 1/3 2017 Honda Accord Headlight Replacement, Headlight: 1 단계, 이미지 2/3 2017 Honda Accord Headlight Replacement, Headlight: 1 단계, 이미지 3/3
    • Pull the Hood Latch lever inside the car, located under the steering wheel.
    • Lift the hood while pressing up on the lever under the front of the hood.
  2. 2017 Honda Accord Headlight Replacement: 2 단계, 이미지 1/2 2017 Honda Accord Headlight Replacement: 2 단계, 이미지 2/2
    • Lift up the hood prop rod and insert it into the hole on the underside of the hood.
  3. 2017 Honda Accord Headlight Replacement: 3 단계, 이미지 1/2 2017 Honda Accord Headlight Replacement: 3 단계, 이미지 2/2
    • Use a 1/4" ratcheting wrench and a 10mm socket to loosen the bolt on the negative terminal head.
    • Lift the terminal up off of the battery and place it to the side.
  4. 2017 Honda Accord Headlight Replacement: 4 단계, 이미지 1/1
    • Use the clip remover tool to pry the clip up to remove it.
  5. 2017 Honda Accord Headlight Replacement: 5 단계, 이미지 1/3 2017 Honda Accord Headlight Replacement: 5 단계, 이미지 2/3 2017 Honda Accord Headlight Replacement: 5 단계, 이미지 3/3
    • Use a 1/4" ratcheting wrench and a 10mm socket to remove the three bolts.
  6. 2017 Honda Accord Headlight Replacement: 6 단계, 이미지 1/1
    • Use a 1/4" ratcheting wrench, a 6" extension and a 10mm socket to remove the last bolt.
  7. 2017 Honda Accord Headlight Replacement: 7 단계, 이미지 1/2 2017 Honda Accord Headlight Replacement: 7 단계, 이미지 2/2
    • Gently pull the headlight out.
  8. 2017 Honda Accord Headlight Replacement: 8 단계, 이미지 1/2 2017 Honda Accord Headlight Replacement: 8 단계, 이미지 2/2
    • Press the tab on the connector and pull. Do this for all 4 connectors.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dennis Kravtsov
회원 가입일: 10/07/19
184 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 115
전체 시간: 3,356
