주요 콘텐츠로 건너뛰기
2017 Honda Civic Sport Brake Light Bulb Replacement
필요한 것
  1. 2017 Honda Civic Sport Brake Light Bulb Replacement, Brake Light Bulb: 1 단계, 이미지 1/3 2017 Honda Civic Sport Brake Light Bulb Replacement, Brake Light Bulb: 1 단계, 이미지 2/3 2017 Honda Civic Sport Brake Light Bulb Replacement, Brake Light Bulb: 1 단계, 이미지 3/3
    • Turn your vehicle off before beginning.
    • Open your trunk.
    • Use a Phillips #2 screwdriver to remove the two screws securing the shield.
  2. 2017 Honda Civic Sport Brake Light Bulb Replacement: 2 단계, 이미지 1/3 2017 Honda Civic Sport Brake Light Bulb Replacement: 2 단계, 이미지 2/3 2017 Honda Civic Sport Brake Light Bulb Replacement: 2 단계, 이미지 3/3
    • To remove the brake light housing, start from the top of the frame and pull the shield outwards.
  3. 2017 Honda Civic Sport Brake Light Bulb Replacement: 3 단계, 이미지 1/3 2017 Honda Civic Sport Brake Light Bulb Replacement: 3 단계, 이미지 2/3 2017 Honda Civic Sport Brake Light Bulb Replacement: 3 단계, 이미지 3/3
    • Twist the brake light socket counterclockwise and pull it directly out, with care not to damage the wires.
    • The brake light has a gray plug.
  4. 2017 Honda Civic Sport Brake Light Bulb Replacement: 4 단계, 이미지 1/2 2017 Honda Civic Sport Brake Light Bulb Replacement: 4 단계, 이미지 2/2
    • Grip light bulb and slide it directly out of its socket.
  5. 2017 Honda Civic Sport Brake Light Bulb Replacement: 5 단계, 이미지 1/3 2017 Honda Civic Sport Brake Light Bulb Replacement: 5 단계, 이미지 2/3 2017 Honda Civic Sport Brake Light Bulb Replacement: 5 단계, 이미지 3/3
    • Install a new bulb by pressing it into the socket.
    • You'll hear a "click" when it's properly inserted.
  6. 2017 Honda Civic Sport Brake Light Bulb Replacement: 6 단계, 이미지 1/2 2017 Honda Civic Sport Brake Light Bulb Replacement: 6 단계, 이미지 2/2
    • Place the socket back in its housing and twist it clockwise.
  7. 2017 Honda Civic Sport Brake Light Bulb Replacement: 7 단계, 이미지 1/2 2017 Honda Civic Sport Brake Light Bulb Replacement: 7 단계, 이미지 2/2
    • Align the brake light shield with the two sockets and firmly press the brake light inward.
    • You'll hear a "pop" when the shield is secured.
결론
Enjoy your functional brake light!
다른 2명이 해당 안내서를 완성하였습니다.
Theo Chisom
회원 가입일: 03/01/22
177 평판
안내서 1개 작성함
University of Memphis, Team 2-12, Willis Spring 2022 University of Memphis, Team 2-12, Willis Spring 2022 회원
UM-WILLIS-S22S2G12
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 41
30일 전: 198
전체 시간: 4,176
